Question about E-Machines T1100 PC Desktop
System Configuration Is Not Valid Under Setup Screen
I Need To Know How To Successfully Program the PhoenixBIOS Setup Utility So The Operating System Will Work Properly with step by step instructions and if that Fails I Will Also Need Instructions on how to Install Windows Vista From Scratch With No Current Operating System
    President:
  • 2,692 Answers
Gateway ta1 starting in phoenixbios setup utility.
insert a cd/dvd/bootable flash drive with a windows/linux setup on it and reboot to install an operating system.
Sep 09, 2014 | Computers & Internet
NEC laptop stuck in Phoenix BIOS Setup Utility
While in the BIOS setup utility, go through the tabs/menus looking for BOOT sequence. Configure the laptop to boot from CD-Drive before any other drive. Have the installation CD in drive.Save the changes made to the BIOS configuration, and exit the BIOS. Reboot.
If the installation medium itself does not have a problem, you should be able to boot from it and have the opportunity to install the operating system.
Jan 29, 2014 | NEC Computers & Internet
I want to change language of my ibm netvista desktop
The IBM Netvista should have options to change the language settings built in if you read the manual but generally, if you follow these instructions it usually works.
Go to the BIOS utility and change the language:
To run the Setup Utility program, use the following procedure.
1. Shut down the computer and wait for all lights go off.
2. Start the computer.
3. When the Setup Utility prompt appears on the screen during start-up, press F1. A Setup Utility menu will appear.
4. Follow the instructions on the screen.
5. When finished, select System Summary to verify that any configuration changes have been accepted.
Feb 06, 2013 | IBM NetVista PC Desktop
Bios nonva 5600 aspire
The BIOS Setup Utility is a hardware configuration program built into your computer's BIOS (Basic Input/Output System).
Your computer is already properly configured and optimized, and you do not need to run this utility.
However,if you encounter configuration problems, you may need to run Setup.
To activate the BIOS Utility, press
m
during POST (when "Press <F2> to enter Setup" message is promptedon the bottom of screen).
The setup screen displays BIOS as follows:Navigating the BIOS UtilityDuring setup,all Fn function keys and power saving functions are disabled.
There are five menu options:
Main, Advanced, Security, Boot and Exit.Follow these instructions:
To choose a menu, use the cursor left/right keys (zx).
To choose a parameter, use the cursor up/down keys (wy).
To change the value of a parameter, press p or q
Press
while you are in any of the menu options to go to the Exit menu.
In any menu, you can load default settings by pressing t
You can also press u
to save any changes made and exit the BIOS Setup Utility.
hope this helps
Aug 02, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
Invalid configuration information
Start your computer and after the BIOS screen disappers , begin rapidly pressing PF8 until the Windows Boot Options appear. You should see "Safe Mode", "Boot from last valid configuration", and "Normal Mode", and maybe a few others. Select "Last Valid Configuration." Computer should sucessfully boot.
Jan 17, 2012 | Microsoft Windows XP Home Edition...
ACER ASPIRE 3680 --OPERATING SYSTEM NOT FOUND
its showing operating system not found, because the system cannot detect your hard disk.
Open your system, remove and fix back the hard disk, then try again.
Take care.
Mar 03, 2010 | Computers & Internet
I would like reset the password of my d33005 motherboard
Go into the BIOS setup to reset the password. Start by rebooting the system. Before the system starts loading the operating system, the computer will give an opportunity to enter the BIOS setup utility. Usually a screen appears saying to press a key to enter the setup utility; i.e. "Hit DEL to enter Setup". You have to know what key the computer is looking for to get to Setup. DEL in used on the a lot of ASUS machines but you may that to refer to a manual or read the screen just before the operating systems to load. Once you get in, look for something related to security settings. Once it is found under the boot tab. Here is where you can reset the motherboard password. Hope this helps.
Dec 15, 2009 | ASUS Computers & Internet
Acer aspire 5610 and phoenixbios setup utility password
please send me now phoenixbios setup utility...
Best regard
May 10, 2009 | Acer Aspire 5610-4648 Notebook
Will not complete boot sequeance
Can you get into safe mode? If so then do a system restore to the last known date that you know the laptop was booting properly.
Jan 27, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Problem with recovery of the system (Windows XP)
check the status of harddisk on bios, whether detecting it or not if detecting then also check the hdd status, change its native status
Oct 24, 2008 | Toshiba Satellite A135-S4527 Notebook
E-Machines T1100 PC Desktop Logo
113 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
