Question about Kenmore 54501 Dehumidifier
My hose connection is leaking water
I recently hooked this new machine up to a hose that is draining in a sink. The hose was purchased at the local hardware store. It fits perfectly with the hose connection. The water drips out between the connection....right at the joint. I'm not sure if it is a gravity issue since the hose is not exactly level from the exit at back or if it is just that the connection is faulty. a) any ideas how I can fix this? b) do you think there is a difference purchasing a hose connection from a non-Kenmore source? Thanks for your help. Jonathan
  • 883 Answers
Jonathan, first unscrew the hose connection. Now look into the end of the hose for a rubber seal. The color of the seal may be black or green or red or yellow or some other color. Does this seal exist at all? I once had purchased a hose and found out the seal had fallen out sometime before I got it home. If the seal is there, remove it and get another seal. They are inexpensive, but usually must be purchased in quantities of 10 or more.
Posted on Aug 03, 2007
  • Marty marty Aug 04, 2007
    Jonathan,
    I see you rated me as "almost there"...did you find the seal?
SOURCE:
Model DM32M Haier Dehumidifier. I am missing a part which diverts the water into the hose drain. All the water now goes directly into the bucket. I want it to drain into the sink nearby.
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Sep 22, 2017 | Haier Dehumidifiers
Once you punch a hole in the receptacle, what type of screw cap would fit.
Most of the hose/drain connections i have seen on these have a std gardenhose fitting so you can use a std garden hose to direct the water over to drain, caps for garden hoses are easyly available from any garden supply store , but i do caution you on your thought process of hooking up a hose makes this a maintence free option, it does not as hose and filters still need constant cleaning , especally in high humidity seasons
Sep 09, 2014 | Whirlpool AD40DSL Dehumidifier
I have a Maytag dehumidifier M7DH45B2A, and want to connect a drain hose, as opposed to using the bucket as we always have. What kind of hose, and do I just remove the bucket and hook up to the same...
Unless it can be 100% gravity feed (1 inch drop per foot) you might need this:
Part: WPL8212501
Fits Maytag M7DH45B2A 496719-1.jpg (Click images to Enlarge)
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status: In Stock
Price:
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
Jun 02, 2011 | Maytag M7DH45B2A Dehumidifier
I have a Maytag M7DH65B2A. I hooked up a hose to
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 20, 2009 | Maytag M7DH65B2A Dehumidifier
Hose connected to drain, but still leaks water on floor
Jul 12, 2009 | Maytag M7DH65B2A Dehumidifier
Help! Water keeps filling the tank instead of going out the hose
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
LG dehumidifier won't drain through hose anymore.
Make sure hose is flat with no high or low spots. Blow or **** out hose and pour somr bleach water through hose.
Jun 30, 2009 | LG LD65EL Dehumidifier
Dehumidifier emptys in the floor.
Check the float first - be sure the styrofoam on the bottom is still intact.  Be sure that you can move it up and down freely (and easily) with the bucket out of the machine.  If that is not bound up, and the foam is in place, next check the switch in the dehumidifier itself.  It's directly behind where the float goes - the way to test it is to turn the dehumidifier on and push the metal tab in with your finger.  The machine should cut out immediately - if it does not - the microswitch needs to be replaced.  (they're very cheap, and simple to replace)
Sep 13, 2008 | Maytag M7DH45B2A Dehumidifier
I have a Kenmore 54501 dehumidifier
hi,
somewhere there is a "knockout" or "plug" or something similar you have to remove or replace it to get it to drain through the hose, there should be some documentation in the owners manual about it, try troubleshooting in the back of the manual. If not look directly into the hose outlet and see if theres a plastic plug there, if there is use a screwdriver or something similar to GENTLY remove the plug, you may have to just study the machine when its running to get a better idea of how the water drains, maybe the machine came with something like it in one of the plastic bags the accessories came in.
good luck
J
Jul 23, 2008 | Kenmore 54501 Dehumidifier
Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Jun 03, 2008 | Frigidaire FDL25P1 Dehumidifier
Kenmore 54501 Dehumidifier Logo
302 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
