Question about Humminbird 561 Fishfinder
Humminbird 561 problems -solutions
Looses depth at cruising speed
2 Suggested Answers
  • 29 Answers
SOURCE: I have a humminbird pmax 170. It does not show
Contact our customer service group and they will be able to help you. There number is 800-633-1468.
Posted on Jan 11, 2011
Humminbird 561 screen lights up then goes blank
Sounds like main board fault. Check the battery voltage too. If it is less than normal, this kind of fault can occur. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 01, 2014 | Humminbird 561 Fishfinder
I get an inacccurate depth reading
All electronics when they age the electrolytic capacitors dry up and need replacing, and you get aging solder joints that increase in resistance... this could be giving you false readings.
Nov 30, 2013 | Humminbird 561 Fishfinder
The unit loses the signal at higher speeds
The signal loss is due to the transducer not in the water. Suggest remounting the Xducer an inch or 2 lower to be in water when you plane out at full throttle.
Sep 04, 2013 | Humminbird 561 Fishfinder
Does the 561 need an inline fuse,and what size of fuse.
Best precaution is an in-line fuse of a Slow Blow 5 amp near the battery or power distribution terminal.
Apr 16, 2013 | Humminbird 561 Fishfinder
I need a longer power cable for my humminbird 561, is it possible
don't splice them bad bad bad call hummingbird order you a set of power cables
Apr 11, 2013 | Humminbird 561 Fishfinder
I need a longer power cable for my 561 fish finder
they have longer power cables at hummingbird call em order you one
My dept finder reads gives me the wrong depth. Is there a way to calibrate this. I doint know the modle off hand. It is the one that gives you two side views and stright dowm. It has the temp. and speed.
If your depth is off because of where your transducer is located, calibration can be done through the menu by adding or subtracting a foot or two.  In your never to be read manual are all the instructions necessary.  If you are off by more than a foot or 2, chances are your transducer is bad.
http://www.humminbird.com/support/ProductManuals.aspx should allow you to download the manual for free and even step you through some troubleshooting.
Aug 09, 2011 | Humminbird Sport & Outdoor - Others
Depth and speed are reading accurately however the sonar is skipping meaning it reads for a couple of seconds then blank for a few seconds. No visible nicks in the transducer cable everything is secure. ...
My name is Mike. I understand your problem. What I am doing to help you the best I can, is giving you the manual to download in PDF as well as a support number and other information to help you out. Also giving you my direct page to my Services I offer. Thanks SO Much , Mike.
http://store.humminbird.com/media/document/587_597_HD_DI_Manual.pdf
http://store.humminbird.com/products/399598/587ci_HD_Combo
MY PERSONAL MARKET PLACE SERVICES I OFFER
http://beta.fixya.com/users/mc1beanThank You, Again. Please rate my solution for my free help and some nice comments back would be grateful. God Bless, Mike
Jun 06, 2011 | Humminbird 2009 587ci Gps/fishfinder...
My Humminbird 788 ci screen clutters up and gives crazy depth readings when the trolling motor (mk terrpva80# w/ ipilot and built in td w/mkr-us2-8 cable) is set on mid to high speed settings. It does...
One thing you might try is restoring the defaults in your unit. One other thing is go into the menu under the sonar tab and adjust your Noise Filter. You may have some type of interference going on. You can call our customer service department and they will trouble shoot it for you. Our number is 800-633-1468.
Joby from Humminbird.
Jan 01, 2011 | Humminbird 787c2 Combo GPS Receiver
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
Humminbird 561 Fishfinder Logo
70 people viewed this question
Top Humminbird Boating Experts
Phil Walker
Phil Walker
Steve
Steve
fordexpert
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
