Question about Dell Inspiron 1525 Notebook
Dell inspiron 1525 will not charge the battery
After several months, the battery would not charge any more. dell sent me a new power adapter. that did not fix the problem. i was able to charge my battery on a friend's computer, so there is nothing wrong with my battery
  • 6 more comments
  • Anonymous Mar 18, 2009
    when i have the adapter plugged in the battery icon says 0% available, plugged in, not charging
  • msreddy1341 Apr 05, 2009
    My Battery is not getting Charged when i pluged in it shows
    0% available(Pluged in, Charging) and No battery Detected.
    Plz can any one help
  • Abhinavkish Apr 16, 2009
    My dell ispiron 1525 battery was working fine, Suddenly one day it started showing 0% available, not connected. I can work on my laptop with power on, but no battery backup is available. now after one week of that proble it is showing no battery detected. please help me out. My warranty for 1 year got expired just now.
  • marshmf May 02, 2009
    Same problem. Sometimes it charges but most of the time it doesn't. Very annoying.
  • Anonymous May 05, 2009
    My laptop is doing the same thing. Most people I've talked to have this problem also. One of my friends had to get a new motherboard for hers and it fixed it, but I don't want to buy a new one. I've only had this lapton for 8 months..
  • foospro May 21, 2009
    I have the same problem as do apparently thousands of other Dell owners since there are many forums on this when searched in Google. It doesn't seem to matter what model of laptop you have, it is just a Dell problem. Nobody has a solution, not even tech support. It is not the charger or the battery, it is the crappy Dell computer. I guess you get what you pay for. My best advice is to tell everyone how bad Dell sucks and buy an HP.
  • daneshkt
    daneshkt Jul 03, 2012
    hello dear can you please send me diagram or method to repair old power board of dell 1525, i want to use same board rather than new,if it is possible
    regards
    Danesh
    daneshkt@yahoo.com
  • Fix Your PC.Mobi
    Fix Your PC.Mobi Oct 13, 2014
    there is a core voltage along with the regular voltage on most laptops . Make shure that the core voltage matches up.
    Scholar:
  • 101 Answers
1525 owners (possibly other models) DO NOT replace the mobo before reading this! Just read step 3 and 3a.
The Dell 1525, 600 series, and probably all other models using PA10 or PA12 power supplies have a power jack that uses the center pin to detect the presence of a genuine Dell power adapter. There have been considerable writings on the problems with this 3rd pin on the internet.
The symptom is that you can run the laptop when plugged in but the battery won't charge and you get a warning message that you are not using the proper power supply or it can not be identified.
The best place to see power supply status in the BIOS under battery status.
You MUST use a genuine Dell adapter, period. None of the non OEM supplies have the center pin enabled (proprietary chip).
CAUSES:
1. The power adapter sensing line can be damaged by static electricity but I find this to be rare.
2. The center pin in the power supply is loose or the wires are breaking (test by wiggling the power cord at the strain relief while holding the plug steady in the laptop - replace the power supply for $<20 on eBay.
3. The center pin connector on the laptop jack is loose - symptom is that it works sometimes and not others. Requires a full breakdown and replacement of the jack. Can be done yourself if you are very handy AND WILLING to FOLLOW DIRECTIONS which are excellent on the Dell web site. Does require soldering on most laptops.
3a. At least on the 1525 there is a sub board for the power and USB which you can get for $80 on eBay and just plugs in - still requires pretty much total breakdown. The board itself is usually the problem so replacing the connector won't help - it is in the multilayer trace from the power jack to the mobo connector. There is a bypass wiring method that requires super close tolerance soldering - I will post that if asked.
4. On some older models (P4 1 core) you can go into the BIOS and turn off Intel speed step to get the laptop running - it will run slower but you probably won't even notice the diff.
This whole mess is the result of Dell trying to protect the mobo and battery (life and fire prevention) but packing too much wiring into a too small package. They should have used a larger, 3 prong type power jack knowing how much strain is put on the power cord.
Posted on Nov 11, 2009
  • Jon Hunter Nov 26, 2010
    price on the power sub board now in the $30 range on eBay - just make sure you get one guaranteed and tested as I have seen ones that have the same fault!
  • daneshkt
    regards
    Danesh
    daneshkt@yahoo.com
PROBLEM FOUND AND FIXED!!
The problem is as JCHUNTER identified. On my Inspiron 1525 I got the same dreaded message "plugged in...not charging." What I found is this: The problem is NOT the charger. the problem is NOT the motherboard (at least it wasn't) on mi laptop. The problem is the jack on the laptop that the charger plugs into. There are 3 metal contact parts on the charger jack that mates with three essential contacts in the charger input jack on the laptop. If you look at the charger tip you will notice (1) the outside metal piece, (2) the inside of that same outside metal piece, and, (3) (the metal tip inside that looks like a piece of bare silver wire (forgive me, I do not have the technical terms). If you look inside the power input jact on the laptop (does not require any opening of the laptop) you will see a rounded black piece in the center of the input. This iw where the problems lies. There are four metal contact points on that inside piece that must be in contact with the inside metal on the charger (#2 above). Over time, these four metal contacts gets pushed inside the rounded black center piece on the input jact so that they fail to maintain constant contact with the corresponding area of the charger, so you get the dreaded message.
Here are possible fixes:
1. replace the sub-board on which the power input jack & USB jacks are located (I do not know if all inspirons have this sub-board but mine did). To me it was not that difficult to open the computer and take that part out. P.S., I did not even have to remove the motherboard. OR
2. Replace just the power input jack (if you are good with soldering micro circuitry. Do so at your own risk. OR
3. This is what I did, and it worked like a charm. Find a way to pull out the four metal contacts on the inner black piece of the input jack of the laptop. This requires a little ingenuity and some patience. I took a straight pin and using a pliers bent the point so that it formed an "L' shape (the bent piece should be short enough so that you can fit it inside the powe jack and maneuver it around). Hook the bent end of the pin under each of the four contact pieces and gently pry them outward. It is my belief that as long as at least one pin gets contact with the charger that it should work.
(Some people suggested banging the laptop or wiggling the charger tip and some strange other tactis, which appear to work for some people. I have tried them and found that some work intermittently at best. They will work only as long as there is contact of the two parts I mentioned above).
To arrive at my solution, I opened up my Inspiron 1525. I put a multitester on the power input jact and realized that there was no problem with the sub-board or its connection to the mainboard. I tested the charger and that was fine also. Next I checked the power input jack and the contact points I identified as 1 and 3 above had good contact. It was difficult to check no 2. For this, I used a piece of tin foil placed inside the charger tip before inserting the charger tip into the power input jact on the laptop - and WOW, IT WORKED - NO MORE MESSAGE. I unplugged and removed the foil and.. you guessed it... the message was back. So, I knew that this had to be the problem. Since I used method 3 above, my laptop has been working like a charm, even after multiple times reinserting the charger into the power input jack on the laptop.
This is only my experience. I am no expert. I am just some one who uses self to save tons of cash.
HOPE THIS HELPS SOMEONE!!
Posted on Apr 12, 2010
  • 2 more comments
  • rfagan_nl Aug 26, 2010
    Thanks for the lead. My problem was the centre pin lead was broken inside the cable plug. I cut into the hard plastic base of the plug and re soldered it. Works like a charm. I thought it was open again, but later discovered the blue led on the laptop only flashes every 10 seconds when the battery is almost charged, and not at all when it is fully charged. It was on solid when the battery was dead or very low.
  • Yomammy01 Sep 15, 2010
    Can you tell me the easiest way to take the Dell Inspiron 1525 apart to the level needed to replace the power board? Please do not refere me to the dell service manual site. Any pictures would be great as well! Many thanks!
  • mg247 Jan 25, 2011
    Great idea! Trimmed up a piece of aluminum foil, slipped the plug into the jack and walla! The laptop came to life. Probably won't charge my battery but at least I can use the unit until I get a new one (not Dell)
    Thanks again
  • Creice Mar 12, 2011
    Sorry, I tried your solution, but it didn't work. When I had the problem the first time, I tightened up the screw on the power daughter board and it first worked fine.
    But now the battery again doesn't charge. I carefully pried out the contact pieces inside the power jack (there are six in my power jack), but it didn't work. I also tried the work-around with the tin foil, but it didn't work either.
    Charger is fine, battery too. Do I have to replace the power daughter board?
  • 15 Answers
Hi! i think i know whats wrong with your notebook, since the new ac adapter replacement did not work and you were able to charge your battery on a friends laptop, there is something wrong with mother board, to check this out, upon turning the computer on keep tapping on F2 under BIOS check "Battery Info" if it shows AC ADAPTER UNKNOWN and the BATTERY is IDLE it means mother board needs to be replaced. if you are still under warranty call dell for a mother board replacement.
if this helps please rate.
thanks
PJBHOi
Posted on Mar 12, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
VanDeretto has it exactly right... a loose screw. Follow the Dell instructions to remove the top cover http://support.dell.com/support/edocs/systems/ins1525/en/SM/cntrcont.htm#wp1180201
Then find the small phillips head screw that secures the connector.. it'll be loose.
dell inspiron 1525 will not charge the battery - 381a884.jpg Tighten it and close 'er up.. you're done!
Posted on Jun 11, 2010
  • Candidato Abogado Aug 16, 2010
    Did not work for me... :)
  • nflstatnut Mar 14, 2011
    I had the Plugged in Not Charging message and tried a different battery and adapter from identical model (Inspiron 1525). Neither one worked. The screw was loose on the adapter board and was the cause of the message and not charging.
I had the same problem with a friends 1525 and solved it by doing the following.
Remove the battery from the bottom of the laptop and remove the 2 small screws that are under the battery.
Now remove the plastic cover from the front of the laptop by placing a flat headed screwdriver under the lip on the right hand side until it clicks. Open the screen wide open and the cover should pop off (be careful not to damage the ribbon that's attached).
You should now be able to see the back of the AC powere connector. In my case, the screw that hold the PCB board was loose - so I just tightened it and the battery started taking a charge again.
Hope this helps.
Cheers,
VanDeretto
Posted on Feb 25, 2010
    Problem Solver:
  • 8 Answers
I posted a very detailed blog about this problem. The idea is that you leave a comment about your 1525, and for every 100 people that have the problem I'll send another email and phone call in to Dell complaining about the issue. Hopefully we'll raise some flags on this and get a recall going! Here's the link...hope it helps some of you!
http://thetechguyblog.com/?p=174
Posted on Mar 12, 2010
I had this exact problem and it was solved by tightening the screw in Hoot1020's description. Others may have had different problems but this was exactly what was wrong with mine!!
Posted on Sep 22, 2010
Dear JCHunter 1525 owners (possibly other models) DO NOT replace the mobo before reading this! Just read step 3 and 3a.
Regarding the Problems faced related to Inspiron 1525. I would like to ask u the bypass wire connections from the DC Power Jack board and the Mother Board. Want to try that is that gonna work if I use the bypass wire connections. I hv tried to check the power supplies for the charger. Its 19 V DC. and dint get to know about the third pin potential difference. Wat does the 3rd pin exactly do in the charger connector. does it hv any potential difference of its voltage free. How does it acts as a detector for the Dell charger if its not hving any potential difference. I believe that u hv known a bit in deep for this solution so Im requesting u for the details and awaited. Im cant handle Soldering on the DC jack board and the charger. Thnx in Advance and ur reply wil b appreciated. Regards Amin.
Posted on Feb 16, 2010
Okay guys has stupid has this sound a loose screw is the source of all the problems follow solution #5 and if it still doesent work clean the inside of your power wire (Where The Needle Is) with WD-40 And problem solved worked for me ^__^ hope it works for you good luck
Posted on May 04, 2010
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 49 Answers
Battery not charge?
er...you can reference the artilc :1525 battery not charging
maybe it can help you !
Posted on Jan 14, 2010
Dell Inspiron 1525 Power Jack Board
http://www.powerjackshop.com/Dell/Dell-Inspiron-1525.html
Posted on Oct 09, 2012
I didnt read all the answers so if this solution is already posted, i apologize! ive had the same problem with my 2year old dell, for about the past 6 mons. i read in another forum to try this:
shut down computer
remove battery
turn on computer(must be plugged in)
reinstall the battery(with comp on)
WALA!
magic, i know. im not technologically savvy enough to explain why this works, but it worked for me! my battery has gone from 1% to 12% in the minute it took me to write this :) good luck and hope this helps someone from searching google for hours like i did! :)
Posted on Jul 04, 2012
I had a Dell Inspiron 1525 not charging. It turned out to be a small inexpensive part that was only $39.99 to fix it yourself. I didn't really feel comfortable taking my laptop apart myself. I just mailed it to these guys and they had it fixed really quick for $99 including parts, labor, and return shipping. They have an article that will help you figure out what the problem is too. Check it out: http://njrefurbpc.com/magento/dell-inspiron-1525-not-charging
Hope this helps, and good luck. I was getting ready to toss my laptop out the window, but now its working great.
Posted on Feb 02, 2011
  • Tommy_DE Feb 02, 2011
    Edit: Fixed link
    Dell Inspiron 1525 Not Charging
  • 3 Answers
Just reflash/downgrade bios and you will back to normal. Bios update sometimes cause problem
Posted on Aug 29, 2011
Hi my son has a 1525 its just 18mths old and wouldn't hold charge, Dell have replaced the battery, put 2 new motherboards and 2 new chargers ( all reconditioned not new as per t & c's ) and were going to replace the hard drive, so a new computer, but they dont replace or refund, it has now charging but the software has been corrupted by the system keep shutting down invoulanterilly ( that's what i was told by the technician who's replaced the parts for dell ), the screen has now gone all around the edge and the facia bezel has broken, don't know about DELL more like HELL!!!!!.
If your laptop is not that old but out of warrenty and Dell wont do anything get in touch with Consumer Direct, who deal with all consumer complaints as it sounds like yours to is not fit for the perpose it was designed for under the sale of goods act 1977 and you should be intitelled to a repair replace or a refund.
hope this helps
regards Dean
Posted on Jan 11, 2010
This reminds me of a cell phone I used a couple of years ago. What happened with it was the battery completely discharged one time. Then the power management program it used didn't allow the charge to pass through to the battery. So, I used another charger, cut the end it off, pulled the red and black apart, and pressed it to the battery for 5-10 seconds on the coresponding + and - bars. Put the battery in immediately, and it would charge again. I wonder it this isn't similiar. I don't have an additional charger to try.
Posted on Jul 24, 2009
  • 846 Answers
If you've replaced the battery, and charger and it still won't charge i would assume there is an issue with your logic board. Could be that the charging port is just loose. If you're out of warranty, somebody has to open the Laptop and replace the part. The part is available on ebay. Here's a guide on how to disassemble a Laptop. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Laptop Repair Services.
Posted on Aug 15, 2010
  • Michael Smith Dec 19, 2010
    the link does not even mention Dell computers. nice spam
    Problem Solver:
  • 18 Answers
This Is The Simplest Solution All You Need To Do Is Spray The End Of The Charger Cable (The Bit Where You Plug It In To The Laptop) If You Look There Will Be A Little Silver Pin Spray That With WD-40 It Works Like A Charm And Its Very Easy! Hope It Works For You
Posted on Jun 26, 2010
I solved this by removing and replacing the battery while connected to the power. After replacing the battery I got "Plugged in, Charging".
Posted on Nov 25, 2010
I found some tips "Dell Inspiron 1525 Battery Q&A"
May be some help
If the dell inspiron 1525 battery is dead, I suggest to buy a third-party one (Much cheaper than original battery)
Posted on May 31, 2010
    Problem Solver:
How can resolve the charging problem dell 1525
Posted on Feb 22, 2010
    Problem Solver:
  • 10 Answers
Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
Posted on May 26, 2009
2 Suggested Answers
SOURCE:
daryn720
  • 113 Answers
SOURCE: dell inspiron 1525 will not charge the battery
CHECK IN YOUR BIOS AND MAKE SURE ANY SETTINGS FOR POWER ARE ALL CORRECT ...SO THAT WOULD BE A F2 FUNCTION IF THE ABOVE IS CORRECT ...SEE IF THAT SOLVES THE ISSUE .
Posted on Jun 02, 2009
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 will not power up at all. The adapter works, however the battery is dead. The battery stopped charging about 6mos. after I purchased the unit. I did notice that where you plug the...
i had the same problem... there can be a few reasons why... the adapter i had was at first able to charge the battery... for some reason it stopped charging the battery but was still able to keep the power on... i had a friend who also had a dell laptop and for some reason his adapter was able to charge my battery so it wasnt the battery... i called dell and they sent me another adapter and that was able to charge it...
Jun 16, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Jun 08, 2009 | Dell Inspiron 1525 Notebook
This problem has arised because your motherboard hasn't identified your battery. So, this is motherboard problem.
next time when you chat with the dell representatives, tell them that your motherboard is not recognizing your battery. They would arrange a pickup and would have it repaired in their center.
Good luck,
~regards,
Jegan
Jun 03, 2009 | Dell Inspiron 1525 Notebook
Jun 02, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
44,304 people viewed this question
Clive
Clive
Alun Cox
