Question about Delta Faucet Delta 174-WF Waterfall Single Handle Kitchen Faucet with Spray and Soap Dis...
How do i replace a delta 174 cartridge - Delta Faucet Delta 174-WF Waterfall Single Handle Kitchen Faucet with Spray and Soap Dis...
My Delta 174--WF has a constant drip from the faucet. I'm not sure how to take it apart to fix it, or what parts to replace. Can you help?
Turn off water supply and use allen wrench to remove handle then remove bonnet nut then remove internal parts replacement kits available at most lowe's and other home improvement or hardware store or plumbing supply stores take care to document how everything is removed so you can reinstall exactly how it came out.
Jun 06, 2011 | Delta Faucet Delta 174-WF Waterfall Single...
New installation of a delta rp19804, valve does not close
Sometimes, 'grit' (or something) can get caught in the cartridge... preventing it from closing completely.
Delta's tech support people might be able to talk you through 'flushing' the valve:
DELTA: 1-800-345-3358
If that doesn't fix it, Delta will probably be willing to replace the cartridge for you.
Feb 12, 2011 | Delta Rp19804 Bathroom Accessories...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have 5 of these faucets in my home that was built only 2 years ago. All of these faucets leak from the spout. I have replaced cartridges and they still leak.
Did you replace the seats and springs under the cartridges, Delta part number RP4993. These are the more important parts to replace when your Delta faucet is dripping from the spout.
Sep 03, 2010 | Delta Faucet 2578LHP/H277 Leland 4''...
Delta 1400 series cartridge replacement
The chrome cover needs to be unscrewed with a strap wrench or pair of pliers. Then, you can access the cartridge assembly. You may need an adjustable wrench to unscrew the cartridge.
Apr 12, 2010 | Delta Home
How do i remove the spout to replace o rings on 174 spout?
1. you can pull the spout while turining it. If this still does not work, then spray wd40 at the base and try again. Last resort, deep the spout and base unit in 50/50 solution of white vinegar for a day and then try to take it apart.
The base and spout are snugged fit so you will need to apply some pressure to move it.
Mar 21, 2010 | Delta Faucet Delta 174-SSWF Waterfall...
My Delta Model 174 sputters air when turned on and leaks from the base of the spout. What causes this?
Air is getting into your water line, though I can't imagine how since it's a closed system. The only time this might occur is if the water main was shut off and all the water was drained from the lines. This is only necessary if your doing some plumbing work.
Jan 26, 2010 | Delta Faucet Delta 174-SSWF Waterfall...
Trouble removing the faucet from a Delta Waterfall 174
I wouldn't worry about messing up the threads as it is an old unit that you wish to discard. Do what is necessary to hold the threads still with the vise-grips and loosen the nut until you reach the damaged threads. Then pull the faucet up from the top until the nut hits the bottom of the sink and cut the threaded nipple from the faucet with a hack-saw blade. Lay down cardboard to protect the finish of the sink and surrounding counter top.
I have had to do this many times and it usually saves you the headache of bloody knuckles.
Apr 26, 2009 | Delta Faucet Delta 174-SSWF Waterfall...
Delta Faucet Delta 174-WF Waterfall Single Handle Kitchen Faucet with Spray and Soap Dis... Logo
47 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
