Question about Lexmark E232 Laser Printer
The only light on is the error light
WhenI turn the printer off then back on the only light that is lit is the error light. Earlier when I turned it off then back on it would be normally lit then when i would print something it would start to run the paper through and then say error or something. So I opened the front of the printer took out the cartridge and the thing underneath that and lifted up a little flap and there was the paper. Sorry it isnt so direct. I really dont know what to do. Please get back ASAP! Thank you so much!
  • tesiaharmonj Mar 12, 2009
    Thanks but I did all that. A friend of mine that is a computer tech gave me this printer. He gave me printer and wires thats it. I dont have any software for it. I think it was already installed on the computer!
  • 53 Answers
U need to check if the printer is still having any paper inside. Check gears and rollers if there is any Jam. Try to uninstall and reinstall the printer. And try using calibration option included with the software.
Posted on Mar 12, 2009
  • Prerna Jha Mar 15, 2009
    Try to search for the driver online it might help you real time. Or send me the printer information.
    Thanks
Printer Problem
The drum has come to the end of its life. You should replace the drum assembly and reset the drum counter. Here is the procedure:
power off and open front door
hold down the continue button as you power on printer leaving front door open
when error light comes on release continue and close front door.
toner low, load paper, ready, and continue will all be lit.
press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change
when just toner low is lit, press and hold continue button until lights cycle up and down in sequence.
release continue.. toner low will be lit again
turn printer off, wait 10 secs or so and then back on
press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Apr 09, 2014 | Dell 1720dn Laser Printer
CANON IMAGECLASS MF 7460 CODE E000007. HOW DO I RESET THIS MACHINE.
Its because of Fixing film assembly failure its not solving resetting the machine you need to replace fixing film assy
Feb 07, 2013 | Canon imageCLASS D780 All-In-One Laser...
Reset counter
By the way, what is the make and model of your printer?
  1. Resetting the Drum Page Counter
    • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
    • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
    • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
    • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
    • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
    • 7 Turn the printer off and back on.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Office Equipment & Supplies
I have canon MP510 printer 4 years old not over used. Was ok earlier in the day, now green and yellow lights flashing and paper feed light not lit. shows B200 error message. should I just buy a new...
The error B200 is an internal overheat error. It is usually associated with an overheating print head. The fault can be with the print head,carriage or even the logic board. You will not be able to locate the trouble unless those 3 items are replaced in that sequence. in other words SCRAP it as the costs will be enormous.
srri
Aug 09, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I can not get my printer to work it has all lights blinking
It indicates Fuser Malfunction.When any of the following error is indicated, turn the printer Off, wait 5 seconds and then turn the printer On again.
If the alarm continues, perform a Factory Reset:
  1. Turn the printer off.
  2. Hold in the circular button on the front panel of the printer.
  3. Turn the printer back on.
  4. When the DRUM light is lit by itself let go of the button.
  5. Hold in the circular button on the front panel again.
  6. Once the Alarm light comes on, let go of the button.
  7. This has performed a factory reset on the printer.
(Provided by Brother.com)
Hope this helps.
Bruce
Jun 14, 2011 | Brother HL 1440 Laser Printer
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
All the lights ar fleshing and the printer dident work
1. Turn off your printer on its back 2. Open the front cover 3. Push and hold continue and cancel buttons while turning the printer on again. 4. release when only the error led is lit 5. Close the front cover
Nov 24, 2009 | Dell 1700 Laser Printer
Paper light on but printer has paper
Try reset using this procedure from Fixya past solutions:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Let know if working and do not forget to rate this solution. Thanks
Jan 10, 2009 | Brother HL-2040 Laser Printer
Lexmark E232 Laser Printer Logo
224 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
