Question about Back to Basics SALPHA500 1 Speed Blender
Blade assembly U12-38
Blade assembly is cracked and I wanted to know if anyone sells a replacement part
Need a blade assembly for Black & Decker Blender Model No. BL2010BGC
Fixya does not sell replacement blade assemblies. Check with a local appliance parts supplier.
Oct 26, 2016 | Blenders
Replace ball bearing
Part of the blade assembly or drive socket assembly?...
check here:
Amazon com vitamix wrench assembly Home Kitchen
Jan 30, 2014 | Vitamix Blenders
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Sep 26, 2013 | Waring Blenders
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
I need the Jenn-Air Blender blade assembly too. Anyone sell me one?
Hello, Do you still need the jenn-air blade assembly? I have one to sell. Do you need the collar also?
Jun 28, 2009 | Jenn-Air JBL800 Work Top Blender
Leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Can't find replacement parts for my Thunderstick Pro blender
I can sell you part of mine. I getting a new one to replace a part for mine.
Mar 23, 2009 | Blenders
CBL-10 SPARE PARTS
There is a store at Bondi Junction (Oxford street) where I purchased replacement blades as mine broke. Dont have their details though. Try tracking them down.
Dec 30, 2007 | Breville CBL10 BlendMaster Classic Work...
Back to Basics SALPHA500 1 Speed Blender Logo
41 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
