Question about Raleigh USA Bicycle Company C40
How to raise handle bars on Raleigh C40 - Raleigh USA Bicycle Company C40
2 Suggested Answers
  • 289 Answers
SOURCE: My Raleigh C40 Seatpost came
try click this site. http://www.thewashingmachinepost.net/archive/archivepost368.html
Posted on Aug 03, 2011
Raising handle bars
Should be a set screw or release on the frame where the handlebar stem inserts into the frame. Lossen the connection and with a friend if necessary push down on the frame and pull up on the handelbars to rise the stem. You might need to spray some lubricant where the stem fits into the frame.
Apr 15, 2014 | Raleigh M80
Steering too lose
From the images I have seen of the bike the loose steering could be resolved by tightening the allen screw (hex key) in the goose neck. If you were sitting on your bike and looking at the handle bars, just below where the handle bars adjust, pivot forward or back, there is an allen head bolt going down. Tightening up this bolt should tighten your steering. Some bikes have a standard bolt headed bolt to tighten the steering. Good luck!
Mar 13, 2014 | Raleigh Venture 3.0 20" Mens
How to remove handle bars on Raleigh 3.0
See if this manual works for your bike:
http://www.raleighusa.com/wp-content/uploads/2009/02/09_ra_ownersmanual_lores.pdf
Jan 05, 2013 | Raleigh Venture 3.0 20" Mens
Need a new yoke nut for raleigh mx16 as handle bar stem wont stay in
Read this to get a better understanding of how it all works. Especially the last section.
http://sheldonbrown.com/handsup.html
Then consult a bike shop for the needed part.
Aug 17, 2011 | Cycling
I have a new set of handle bars how do i fix them on to my raleigh bike
Sweetheart, it is hard to answer without seeing your exact situation by photograph, for instance. There are so many "Raleigh" bikes nowadays. If your new bars are exactly the same as the old, a simple visit to the hardware store, if you have one, or a bike shop, will tell you what tools you need. I once knew a chipmonk who could chip wood with its teeth, grin. But I never met a chipmonk who could turn screws or bolts by mere wish-power. Tools are needed, and a friendly adviser. Good luck, and look, for most things are answered by looking closely at them.
Apr 26, 2011 | Cycling
How do you adjust the handle bars on a Raleigh venture 4.0 bike
You should take it back to your dealer and let him adjust it for you. I do not know if you are trying to raise your bar or tip it closer to you. If, you try to raise it, remember that it has to be in the top tube at least 2 1/2 to 3 inches inserted, there is a safety mark, DO NOT GO ABOVE IT, BECAUSE IT CAN SNAP OFF. All bicycles are metric and to tip it towards you just loosen the bracket that goes around the bar, to raise is usually a metric allen, but again unless you know what you are doing have someone do it that can do it right.
Oct 11, 2010 | Cycling
Raise handle bars
At the centre of the handlebars you will note a bolt head that is separate from the ones that lock the handlebars in place. Undo that bolt in an anticlockwise direction. About three full turns should be sufficient. Now take a block of wood and place it on top of the nut to protect the surface of the nut. Get a friend to hold the bike steady because you will need both hands to keep the block of wood on top of the bolt and deliver two sharp blows with a hammer. The handlebars should now be able to be pulled up and down or at least twisted and pulled up and down. Tighten the bolt at desired height
Oct 05, 2010 | Raleigh Diamondback Joker Bicycle '10
Schwinn Impact MOS.....can the handle bars be raised? If so, do you loosen the small star nut on top, or the large nut at the base of the handle bars?
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
May 22, 2010 | Cycling
Need to raise the handle bar on my 2007 Marin Argenta road bike.
The stem for the marin is fixed so you'd have to replace it with one that is higher if you wanted to raise the elevation of your handle bars. You can pivot the handle bars for your preferred angle of comfort though. Loosen the 4 screws on the top of the stem and then you can adjust the handle bars to the correct angle that is best for you.
Jan 09, 2010 | Cycling
Raleigh USA Bicycle Company C40 Logo
65 people viewed this question
Top Raleigh USA Bicycle Company Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Raleigh USA Bicycle Company Cycling Expert? Answer questions, earn points and help others
