Question about Ariens Garden
My ariens 936017 keeps blowing the main fuse - Ariens Garden
SOURCE: Blowing main fuse to fuel pump.
check and make sure the wires on your fuel pump aren't shorting out. i had the same problem due to rust. the positive terminal on the fuel pump was grounding out.
Posted on Aug 24, 2008
  • 13 Answers
SOURCE: I have a ariens riding lawn mower and I keep
look at every wire ...trace it untill you find the striped wire thats touching up against a piece of metal somewhere...or something you may have recently put back together where the wires are now backwards...
the only other thing is something really hot melted it and its grounding out on metal..
CHECK EVERY WIRE...get under there...get dirty...but dont get a headache...ive been there..thats why im writing you man!
Posted on Jul 21, 2009
  • 32 Answers
SOURCE: My 2006 keeps blowing her main fuse!
Most likely it is getting grounded out somewhere, or just bad wiring. Hope i was of help to you!
Posted on Aug 10, 2009
  • 153 Answers
SOURCE: looking for an owners manual/parts manual for
Hello, The top link is to Ariens directly and they should be able to help you, if you still need help please contact me. Thank you. http://www.ariens.com/corporate/Pages/OwnerManuals.aspxhttp://lawnandgarden.manualsonline.com/manuals/mfg/ariens/ariens_lawn_mower_product_list.html
Posted on Jun 06, 2011
  • 457 Answers
SOURCE: tumble dryer blows main fuse
check fuse rate on dryer if same rate. check dryer for amps if pulling to many will blow fuse, if dryer is ok check from plug in to fuse.
Posted on Jul 29, 2012
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Tumble dryer blows main fuse
Jul 29, 2012 | Hotpoint Dryers
Exactly what can blow the main fuse
Hi, Anonymous you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Main Fuse Blows The FZR Forum
View topic 92 FZR600 Keeps Blowing Main Fuse
https://www.tradebit.com/filedetail.php/2864660-yamaha-fzr-600-service-repair-manual-pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 24, 2012 | 1991 Yamaha FZR 600
When turning on pto blows the fuse
Look over the entire wiring harness wherever it may be touching metal as it probably is chaffed, simply tape and zip tie it away from the ground source.
Aug 03, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Toyota Camry 1994 Main Fuse keeps blowing
-if your fuses are blowing
-the problem is in the wiring
-because if too much amperage flows through the fuse will blow
-there's probably a short to ground somewhere or high resistance after the fuses causing it to draw more amps
Mar 19, 2009 | 1994 Toyota Camry
Kawasai z750, keeps blowing main fuse
To my knowledge, there are no onboard electrical/electronic components capable of shorting and blowing the fuse with out blowing any of the secondary fuse. The main fuse could possibly blow due to a short in the wiring or an exposed/frayed wire touching the body. The three most likely areas would be:
  • wire harness leading to the regulator;
  • wire harness leading to the fusebox; and/or
  • wire harness leading to the ignition switch.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 19, 2008 | 2005 kawasaki EL 125 Eliminator
Garden Logo
60 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
