Question about Ariens Garden
My ariens riding mower only will go in forward or reverse very slow if it moves at all
  • 79 Answers
SOURCE: lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Posted on Apr 06, 2009
libaredneck
  • 119 Answers
SOURCE: MTD RIDING MOWER with 618-0229 transmission.
sounds like you need a new drive belt
Posted on May 04, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
nova2nv
  • 197 Answers
SOURCE: my ariens 824 wont go forward or reverse
I would check your traction drive disc for wear or shredding.With low or little fuel in tank you can safely grab handle bars and lift machine up on it's auger housing.Then remove shield from under machine and inspect metal disc with rubber around it.If rubber looks worn you can get a replacement traction drive disc easily from most small engine repair shop's or go online and look for your nearest Ariens dealer.
Posted on Nov 18, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
Why doesn't it move forward or in reverse?
Many tractors and mowers have a key way on the axle and axle bore on the wheel hub.. Did you remove the tire and wheel from the mower axle? ..if you did most likely the drive axle key fell out of its slot on the drive axle and when you replaced the wheel it has no way to drive the wheels..try this start the mower put it in gear and try to move..have someone watch the end of the axle at the wheel
..if the key is missing the axle will be turning..but not the wheel..any good hardware store should carry them. just measure the depth and width of the key..something like 1/4,3/8 etc...good luck..
Aug 16, 2015 | Ariens Garden
Ariens lawn tractor not able to shift out of forward
model number would help as Ariens has made lawn care equipment for like 75 years or something ...
Nov 16, 2013 | Garden
My mower goes just fine in forward gear, but barely moves in reverse, and if on any type of incline, doesn't move at all
If the transmission is serviceable change the oil and filter, change the drive belt as well.... If it's a completely sealed unit, trying changing the drive belt, but it sounds like the transmission has worn out.. Springs, plates... Etc...
Sep 17, 2013 | Ariens Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
My ariens 824 wont go forward or reverse. snow thrower still works. wheels start to move a bit then stop
Nov 18, 2009 | Ariens Garden
My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Sep 26, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens ezr 1742 will not move. everything works fine except it will not go forward or reverse.
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered. Give this a try.
Jun 07, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
81 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
