Question about Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
Reset oil light on YTH21K46 LAWN MOWER - Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
3 Suggested Answers
SOURCE: Disconnecting/bypassing the seat safety switch
I want to disconnect the seat shut off switch on my Husqavna 25 hp lawn tractor
Posted on Oct 20, 2010
  • 2239 Answers
SOURCE: Husqvarna riding lawn mower (YTH21K46), mower blade clutch cable routing.
Its pretty straight forward to fit the cable, if it is not pulling the jockey hard enough into the belt it is more likly the belt is incorrectly fitted or has stretched.
Posted on Jun 02, 2012
I am losing power going up hills and smoke comes out in front of mower
check for excessive oil in the sump (carby needle and seat allowing fuel to drain into the sump past the rings when standing for a period of time )
what you describe is indicative of excess oil and the oil ring cannot handle the oil control
this in turn affects the air/fuel mixture and makes it hard for the engine to run
Jan 09, 2016 | Husqvarna YTH21K46 46" 21HP Kohler Lawn...
Lawn mower is smoking white
to much gas check to see if chock is off or replace bad fuel siliniod rebuild carberator
Aug 27, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Spray starter fluid carb gumout
Is it smoking? Could be cause by oil getting on the plugs or the valves need adjustment.
Jun 20, 2013 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I don't kown anything about charging batteries! How do I carge a battery in a 2008 Husqvarna riding lawn more?
mille get yourself a cooler and put 8 cold beers in it. Put that cooler into the gap between the seat and the "dash" of the mower. Make sure your gas and oil are good. Have someone jump start your mower from a car and then you mow and drink and mow and drink until the beer is all gone. If the mower does not start from the battery the next day go out and buy yourself a new battery. If the battery and charging system are good then you do not have to charge it if it is being used regularly.
Apr 20, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
ENGINE OIL CHANGE QTY
Your owner's manual states: 51 Ounces W/Filter and 35 Ounces of Oil Without Filter. This info can be found under specifications.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_532430577.pdf
Mar 23, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Husqvarna YTH21K46 (46") 21HP Lawn Tractor  960 43 0085 Logo
32 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
