Question about Xerox Phaser 8560MFP Laser Printer
8560 System Error 39,003,40:6082
The 8560 printer states that there is a system error 39,003,40:6082. Can anyone assist me with this problem?
    New Friend:
I can't help. I am getting 39,003.40:17510 on my MHP and I can't find out how to fix it.
Posted on Mar 15, 2014
Replace the scanner assembly(flat bed)
Posted on Apr 07, 2009
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
Can anyone tell me what code 19,003.48 means for Xerox 8560?
19,003.48: Scale and offset error is too large. The voltages measured have more than a 20% error from their expected values. Something is wrong with the Electronics Module or the Wave Amplifier.
To prevent these discharges, a Grounding Clip (P/N 650442700) was added between the Y-Axis Motor mount and the Pick Clutch. Check that this clip is installed and contacts the metallic portion of the Pick Clutch.
Note
The Grounding Clip is factory installed in later versions of 8500/8550
models and in all 8560 models.
Oct 14, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
Xerox error code 09,005.40:19276
Solution : Power OFF the Printer and Contact Support for Assistance Power OFF the Printer and Contact Support for Assistance
Phaser 8560 Support Drivers
May 05, 2014 | Office Equipment & Supplies
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
I have an 8560 MFP with a 04,024,45 error
Power OFF the Printer and Contact Support for Assistance. That's what the support website states. If you run out of warranty Xerox will charge you a call out fee before they even look at the printer.
Mar 15, 2011 | Xerox Phaser 8560MFP Laser Printer
Xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
Feb 04, 2010 | Xerox Phaser 8560DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
System Error
That is an X axis pivot fault of the print head. You have a 1 year on site warranty with that machine.
Call 1-800-835-6100 have your serial number available.
That is not something you can take care of easily.
Sep 23, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
1,157 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
