Question about Canon PIXMA MP530 All-In-One InkJet Printer
Printer says it doesn't have paper when it does
After replacing an ink cartridge, my Canon Pixma 530 stopped recognising the paper in the main feeder, no matter what size paper I put in - just keeps giving me a need to load paper error.
Any suggestions would be appreciated!
  • 53 Answers
Try to put more paper once. Try to check the paper feeder that they are all well set. Try to reboot printer and windows/OS. Than try to print again. You can also try to cancel all the printing jobs pending and than rebooting and trying printing again. But make sure all the flips, tops, lids and other small stuffs of printers are not lose.
Thanx
Posted on Mar 12, 2009
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
PIXMA MP970 InkJet Printer copies ok but does lay ink on documents though printer sounds like it is printing. Have driver for Win 8
This is quite an old printer by this stage and I wonder if it is capable of responding to windows 8 drivers.
Asking Canon through the internet might be a good move.
But Firstly , I would do a complete cartridge clean and make sure they are actually working. You may have to do this twice but it uses a fair bit of ink. If no joy then remove a cartridge and then replace it Does the the printer recognise it or show you that it is full ?
If it says "not recognised" you need to get some replacement cartridges. That should fix it ?
Hope this helps, Michael Tubb.
Jul 10, 2014 | Canon PIXMA MP970 InkJet Printer
I use 3rd party ink and why my color ink light up at my printer pixma mp 287
This will either be because your printer is having trouble recognising the cartridges or warning of low ink because the cartridges have been refilled. Connect a computer to the printer and it will hopefully give you more info.
If your printer cannot recognise the cartridges try wiping the contacts on the front of the cartridges and re-installing. If your printer still doesn't recognise the ink cartridges then sadly they will need replacing.
If it is just a low ink warning then carry on printing untill the printer thinks the cartridges are empty and prevents you from printing. You can them get around this message by pressing the stop/reset/resume button for 5 seconds and continue printing. More information on this can be found here: http://www.refreshcartridges.co.uk/igloo/the-infamous-canon-resumestopreset-button/
Hope this helps.
Feb 21, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mp130 ink cartridge jammed
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon mp145 cartridge not recognised after
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-1
Aug 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a new canon mp210 printer ink is low i bought new ink to replace old their is no ink cartridges in printer. When i look at the pictures to load new ink and put it in alarm light is flashing
Even if the ink level is low, you can continue printing.Press the paperfeed knob for 5 seconds. inklevel indicator will stop now.
Sometimes a new (or refilled) cartridge is not recognised correctly.
When one color is really mt, stop printing and replace inmideatly the colorcartridge.Printing or scanning without the 2 cartridges in place is impossible.
Dec 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma MP950 Ink Refill Error
replace the cartridge with a Canon as the chip has gone on the cartridge.
this is the only way around it with the mp950.
This is to stop them being refilled
May 22, 2008 | Canon Pixma MP950 All-In-One InkJet...
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
153 people viewed this question
old marine
old marine
