Question about Seiko Office Equipment & Supplies
Seiko n681 slow worn out ? - Seiko Office Equipment & Supplies
My Seiko Sonola transistor clock run very slow
Have you tried turning the pendulum up higher to speed it up.
Jan 13, 2013 | Seiko Mantel Clock
Self-winding Seiko watch stops ticking.
Take it in to a watch repairer. Sounds like the self-winding spring is worn if not so then the watch repaier will find the problem. There is nothing you can do so do not attempt to fix it.
Apr 28, 2012 | Watches
My seiko 5 automatic runs to quick
Balance spring in your watch is sticking together and causing the watch to run fast. It can happen when watch gets magnetized or there is some oily residue left on balance spring. To fix this you will have to show your watch to the watchmaker, because this is very specialized job to do and the balance spring is so delicate part, it can be damaged by simple touch.
Feb 28, 2011 | Seiko Watch SNXJ89K1
My Seiko SNA548 Coutura watch slows down. I replaced the battery and it still slows down especially during cold weather. Could it be the the lubricants in the watch are causing the problem?
isnt that model kinetic? if so, if you arent doing about four minutes of aerobic activity in the course of the day, it will go dead. if for some reason you cant (or dont) get much activity, take the ****** off and shake it for a while
Dec 30, 2010 | Seiko Coutura SNA548 Wrist Watch
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
I just purchased my son a Seiko Divers Automatic 200M watch for graduation. For the first few days, the watch worked, but ran about 15-20 minutes fast. Now it won't move at all? Tried wearing it for 8...
Hi mtrahan99. My advice is to take it back and get it replaced, particularly if you have only had it a few days. If they won't exchange it or refund you, get a repair under the guarantee. Automatic watches (and Seiko actually make some very good ones) don't need to be worn all the time to wind them, and the fact that it ran so fast and has now stopped would indicate something major like problems with the mainspring. Return it! Hope this helps; Eagle58
May 19, 2009 | Seiko Divers Automatic watch
My Kinetic watch stopped working.
I highly suspect and probably you also suspect that the energy storage capacitor needs to be replaced. My experience in working on these is that they are only good for about 3-4 years. I only replace with a new Seiko Lithum Ion battery. Check www.timelywatchrepair.com
Aug 02, 2006 | Seiko SKA192 Wrist Watch
199 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Scott Kalvinek
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
