Question about Eureka WhirlWind Litespeed 5844 Upright Vacuum
How to remove the brush roller from the eureka whirlwind big cup vacuum
reddevil6
  • 1673 Answers
SOURCE: How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
Posted on Jan 29, 2008
SOURCE: eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Posted on Jul 24, 2008
galati2k
  • 281 Answers
SOURCE: Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Posted on Apr 23, 2009
  • 5 Answers
SOURCE: eureka 4870 roller only spins in upright
if the belt has been slipping it may have pollished the moteror brush shaft and it just slips. take a small piece of sand paper or enery cloth and ruffen up the shaft to give it some grip.
if the metal shaft of the motor has been heated up due to slippage it will take some doing to ruffun it as the shaft will be hardend due to heat
Posted on May 14, 2009
SOURCE: Changing belt - Eureka Whirlwind 5740
I tried the website for manuals but no luck. I called the toll-free # 1-800-282-2886 and got a rep right away. I gave him the model and s/n (lower bottom on the back side) and he walked me thru it. For the model I have, there are 3 screws to remove - With the vacuum upright and standing facing it - there is on on the right and one on the left of the bottom cover and one on the left side near the hose intake. Remove those to get to the belt. I ordered the belt with him too - althought the belts were cheap ($2.99 for 2) the shipping was $8. If this didnt help - call the 800# - they were great.
Posted on Jun 12, 2009
How to replace eureka model 4388 belt
Hi, it's Allie from Crucial Vacuum!
Changing the belts in your unit is easier than you think. To do so, you will need a phillips head screwdriver. First, start by unplugging your vacuum as a safety measurement. Using the lever in the bottom of your unit, recline your upright until it lays flat. Unscrew all 4 screws from the floor base cover and remove the cover to expose the roller brush and belts of your unit.
Carefully, remove the roller brush by using your hands, make sure to hold on to the side of the roller brush that has the belt so it does not pop out and hit you. Once the roller brush is removed, gently take the belt off the metal spool, and replace with the new belt.
We have a very helpful tutorial in our webpage that can assist you in replacing the belts on your unit:
https://www.youtube.com/watch?v=IFcjzuplX_o
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-style-u-belt-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 19, 2014 | Eureka Whirlwind 4388 Bagless Upright...
Eureka TRUE HEPA Whirlwind Bagless same problem seems...roller just stopped...took everything apart and turned it on just in time to see belt melt...I was able to get the end caps off both sides at first...
If you are able to remove one end cap, the brush roller shaft can be removed and the other bearing is exposed for examination and removal of the hair that probably is clogging it. After cleaning and reassembly the brush roller should rotate freely. Clean any burned belt residue from the motor shaft and install a new Eureka belt.
Aug 02, 2013 | Eureka 2961AVZ Bagless Upright Vacuum
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
How to change belt on eureka whirlwind; what tool do I need
You will first need to remove the hood to gain access to the belt and brush roller. Turn the machine upside down, place the handle on the floor and the base on a counter. You will find several screws that hold on the hood, remove them. Turn the machine back to the upright position and remove the hood. On the right hand side,if your looking the front you will find where the belt goes. At the back you will find a silver shaft sticking out, put the new belt on there first. Then put the brush roller through the belt so it is in the carved out section of the brush roller. Then grab the brush roller by each end and stretch the belt till the brush roller fits back into the base. Turn the brush roller 3 compleat turns backwards and 3 forward to seat the belt in the proper position.
Then put back on the hood.
May 08, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Loss of suction after a burning smell
The belt of the brush roller could of come off and could be causing the smell. Check the belt/brush roller
Feb 10, 2010 | Eureka Whirlwind 4496 Bagless Upright...
Need user/owners manual for Eureka Whirlwind Big Cup model 4686
hello chris. here is the link to use to get your downloadable manual
http://www.eureka.com/owners_guide.jsp
Jun 19, 2009 | Vacuums
I want to replace the belt on an upright eureka vacuum model 4481, any ideas?
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Jun 08, 2009 | Eureka Whirlwind 4481 Upright Vacuum
Dec 08, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
Dec 27, 2007 | Eureka WhirlWind 4381 Upright Vacuum
Eureka WhirlWind Litespeed 5844 Upright Vacuum Logo
47 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
