Question about Acer Aspire 5610-4648 Notebook
What RAM for Acer Aspire 5613AWLMI 533 or 677Mhz?
Hi, I want to update the RAM in my machine, but have seen 2 varieties of speed from RAM suppliers. I'm confused. My Machine is 5613AWLMI 533Mhz FSB 2MB L2 cache etc.
I believe with a faster RAM speed, my machine could run faster 667 > 533? Is this correct? And what RAM would suit me, 2Gig or 4Gig, and can I keep the 1Gig (2 x 512Mb) somehow... like 2.5G of RAM?
Please help,
Paul
  • paul784 Mar 12, 2009
    Thanks for that, very helpful!
    Will 2.5G RAM make my Laptop (Vista Home Premium) function MUCH Better? Is it a 2.5 factor? Or is it best to try and upgrade to the Maximum, so softwares etc run optimally.
    Thanks again!
    Paul
    President:
  • Acer Master
  • 1,314 Answers
Http://www.crucial.com/store/listparts.aspx?model=Aspire%205610
That being said, I'll make the following comments that will hopefully answer your questions.
The maximum memory for your computer is 4 GB. However, if you are using a 32-bit operating system only 3.7 will be available for the system to use minus however much else you are sharing for the video.
Using 667 memory won't make your processor run any faster; the 533 MHz FSB is set in the processor and using 667 memory won't make the memory run any faster either; it will only run at 533. If you do get just 1 2 GB chip to make 2.5 GB total, make sure it is the same speed as the other chip. Usually it's not an issue but sometimes it can be.
Thanks and please take a moment to rate as fixya.
Posted on Mar 12, 2009
  • Kevin Shafer
    Kevin Shafer Mar 12, 2009
    I would recommend to upgrade to the 4 GB for Vista...even though you're losing .3 Vista needs every ounce it can get. However, you will see a noticeably sizeable increase in performance going from 1 to 2.5.
    You're welcome and if you would kindly give this a four star fixya rating, I'd greatly appreciate it. Thanks!
2GB of RAM added but only 1GB usable on an Acer AspireOne (AO532h)
Date 08.09.2013: BIOS BIOS BIOS!!!
2 GB RAM in Acer Aspire One AO532h (2Db):
BIOS 1.25 supports up to 2 GB RAMBIOS 1.26 supports only 1 GB RAM
(the 1,25 version was downloaded from the original homepage today, but perhaps they can change the file...)
Cheers!
Mar 02, 2013 | Acer Aspire One 532h 2268 Netbook
How much maximum ram does acer aspire 4520 support? and is it fine if we have one ram of 2 gb and the other of 1 gb?
Your machine currently has this ram (1GB DDR2 667 SDRAM)
You can upgrade to 4GB DDR2 800MHz ram, sell old one off.
If you use old ram you must exactly match to old in speed, ie 2GB ddr2 667 SDRAM.
I recommend renew with matched larger faster ram 2 + 2 GB DDR800
Dec 18, 2009 | Acer Aspire 4520-5141 Notebook
Hi i have a acer Aspire 7720G RAM?
You have to ask for
DDR 2 - 333MHZ Ram,ie PC2-3200 -- this must be your default ram provided by your manufacturer..
You can also try
DDR 2 - 400MHZ Ram,ie PC2-6400 -- this is next version and it also supported
ENJOY! RATET HIS SOLUTION
RNJ VINOD KUMAR
Aug 08, 2009 | Acer Aspire 7720-6844 Notebook
Hi, I want to upgrade my Acer Aspire 5100 memory to DDR2-800Mhz. Can I do it? Will the motherboard bus support it?
Sorry but the specs for this system states the highest possible ram is DDR2-667 with a max of 4 GB ( 2 X 2gb Ram)
May 11, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 9410 Won't work with two memory slots filled
As you mentioned that you want to use Maximum memory that is supported by 9410, I would like to tell you that you have 32 bit processor in your notebook as its not always advisable to use 4 GB RAM with 32 bit processor as we have seen lots of compatibility issues.Infact in 32 bit processor windows will typically report only 3.2 GB due to a limitation of windows itself.
Mar 25, 2009 | Acer Aspire 9410-4317 Notebook
Directions to install additional RAM on an Acer Aspire.
Ok firstly, ensure you have the correct speed memory stick for the Acer and that it can handle to new total memory capacity you plan to put in. My searches revealed the memory you need is PC2700 and that the notebook can take up to 2Gb total, but again check this with your supplier or look at the RAM memory stick(s) already installed. As for installing them, here is a good YouTube Video:
Please rate my response if it works for you.
Mar 17, 2009 | Acer Computers & Internet
Acer aspire 1640z bios update
That's a memory or RAM error. You need to re-seat the ram of your machine.
Jan 14, 2009 | Acer Aspire 1640Z Notebook
Upgrading Acer Aspire T180
Try putting back the old RAM.
If it does not happen anymore, then it means it was the RAM.
This does not mean that the new CorsairRAM is necessarily faulty, but that it is having compatibility problems with one of the other devices, for example the video adapter.
Nov 04, 2008 | Acer Aspire™ T180 PC Desktop
Acer orbicam
Sir its all due to your hardware doesnt meets your proper drivers! 1st thing you to do is get all necessary software and get it installed. Then it will work! you should visit acer website for proper drivers. Dont worry i will assist you surely
Dec 02, 2007 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
303 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
