Question about GE 24 in. GSD2220Z Built-in Dishwasher
LEAVE MORE WATER THAN SHOULD BE
Hi there, I have a problem with water drain.Actually looks that machine works OK but after work the level of water is too high and water is not 100% clean..It is an inch over the heater.I cleaned all filters and around but it`s same.Dishwasher is old around three years and was not any problem before.Please can you help me to solve the problem.Thanks Milan S.
  • 10,865 Answers
HI Milan. Sounds like you may have a partial obstruction in the drain water pump. To check this out remove the lower front panel and you will see the drain hose attached to a small plastic pump. Disconnect it there and remove the pump from the dishwasher frame so u can look inside of it. Remove any piece of glass or other obstruction in the pump and also check the hose. That should solve it for you.
Posted on Mar 12, 2009
  • Joe Hogan Mar 12, 2009
Smeg Dishwasher not circulating water
Sound like the thermostat doesn't know what the water temperature is set at.
It could be the wash pump. Check to see that the float on the bottom of the DW is unstuck by gently picking it up and setting it down { It is shaped like a mushroom and controls the water level in the bottom of the DW }. Did it move freely?
Dec 29, 2013 | Dishwashers
Locked lite is on machine wont work
If in addation to the light being on and the door is actually locked the most likely problem will be because not all the water drained out of the washer.... the door lock is tied into the water level sensors in the washer and until the water level sensor determines that water has drained it will not unlock the door. The usual reason the water hasnt drained is because the filter screen on the drain pump is built up with debris and the water can not drain,This tip i wrote will tell ya how to take apart the washer to access the pumpo and clean the fliter screen.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 02, 2011 | Kenmore HE2 Plus Front Load Washer
How do I take apart my fisher & paykel top load washer to get to the water pump. I have an error code 37 which means blocked water pump
Hi just read your posting.Now if you look under the machine to the front right you will see a fan.This is your pump.Turn the fan a few times to loosen it.The fan should turn freely.Put the machine back on its feet and select a spin cycle and push the start button.The machine should start to drain.Please reply on how you got on or if the machine still does not drain or for further assistance.Looking forward to your reply.
Oct 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
My dishwasher turns on and all the lights work. It sounds like it's filling up with water, but it never actually runs through any of the cycles. If I leave it running for a while it will continue to...
It's worth repairing.
Check water level switch inside the machine.
Check the inlet solenoid for proper operation. It might have got stuck and remain
in open condition always. You can reach this area by opening the back door of the machine. give a gentle tap with a wooden piece on the valve , it may return to the closed position.
Clean all the inlet and drain areas of the machine.
Sep 21, 2010 | Bosch SHU9915UC Dishwasher
Dishwasher water level drops during washcycle
Check the stand pipe for the drain hose it must be higher than the water in the machine or it will just run out should be 30 inches or higher. I just worked on one with this same problem the drain was about a foot high it would fill and run out almost as fast as it came in.The pump will pump it out when it drains.
Jul 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
Maytag washer model MAV6451AWW - water does not shut off when filling. This started happening after I replaced the main control knob (knob works ok now) could I have loosened another connection which...
This problem is caused by a faulty water level switch.
It is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub.
As the water level increases, pressure increases on the air in the tube. When the pressure reaches a certain level, it activates the switch to turn off the water and signals the timer to start the agitate cycle.
Look for any obstruction or defect in the tube. The switch can be checked for continuity with a multimeter. If it has no continuity the switch is defective..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 16, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Wont fill with water
Hi, Check the drain hose to make sure it hasn't dropped lower than the water level in the washer.
Sometimes when working on the machine, the drain hose gets moved. Does the drain hose go into a sump pump?
PLEASE let me know if this helps or if I can assist you further.
Vic
Jun 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
There is a drain hose that runs from your dishwasher to underneath your sink. (usually connects in right below the drain spout)
It sounds like this may have become clogged, or the sink drain is clogged causing the water to back-up in to the dishwasher drain hose.
Mar 20, 2009 | GE GLD5800L Dishwasher
Water not draining out of dishwasher, goes into spin, but water stays
Low water pressure can be an issues. Also incorrect drain tube install.
For most dishwashers if the water level is below the heating element its actually normal. Sometimes like i said due to hose length or water pressure the water will not always drain but if its below that level its ok.
Last if you have a garbage disposal run it to clear lines.
May 01, 2008 | Dishwashers
Tricity bendix
Water stuck in th machine like what you said is not normal.First you need to drain the water by taking out the hose behind the machine which is into the wall. Plug off first before these jobs. Bring the hose to ground level, the water will run off. Bucket or whatever to collect. Re-fit pipe to correct level in standpipe carefully, without pushing in too deep. The pipe level is important; you can check, there is a water level mark behind machine. You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And don't forget to rate me pl, if the solution has worked......
Dec 08, 2007 | Tricity Bendix AW1000W Front Load Washer
GE 24 in. GSD2220Z Built-in Dishwasher Logo
172 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
