Question about KitchenAid KHM5TB Classic Plus Hand Mixer
The head, on which the mixer is attached, is dipping down too low
When I mix things, the head goes so far down that the mixer part is hitting the bottom of the bowl and scraping it.
  • 135 Answers
HI. You may have asked your question in the wrong mixer category. The following link describes the Kitchenaid mixer at this heading. If this is not your mixer, try again. If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Mar 16, 2009
My Kitchenaid mdl: KSM 155gbca is making a loud bumping noise with or without an attachment.
It is more than likely in the planetary or the fuse gear inside the gear box. Try it once you have the planetary off before you go looking inside the gear box. Easiest is planetary problem but far far more likely is the fuse gear.
Aug 08, 2014 | KitchenAid Artisan Series Tilt-Head Stand...
We have model # KSM90WW. The problem is that the mixer portion hangs down too far into mixing bowl, thus making the mixer "buck" when mixing. Have tried to tighten everything that can be...
Till the top back and look into hinge area. You will see a large set screw that controls how far the head drops. Try turning the screw counter clockwise 1/8 of a turn.
Feb 18, 2011 | KitchenAid Classic Stand Mixer
My beater, dough hook, and wire whip all hit the bottom of the mixing bowl. I have been told that I can adjust them. Can you tell me how? Thank you
On the tilt head models there is a "Stop screw" that adjusts how far down the head goes. I just can't remember if it's in the head or base. I use the other model that lifts the bowl.
Dec 31, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The top of the mixer began shaking and thumping when running, I realized the tilt head is pressed forward a little too far, causing the basic mixing attachment to press too far down into the bowl, maybe by...
Tip the machine upside down on a towel, centralise the hinge pin and tighten the grub screw that locks it into place. This is right up inside the pedestal, there is only one screw there to see.
Now stand it up and fit the mixing bowl & flat paddle, turn the machine on speed one, if the paddle is tinging on the bowl then we now need to set the head height. Turn the motor off.
Raise the motor up and from the front of the machine look in by where the motor hinges on the pedestal. You can see one screw head there. If it's tinging the bowl then you need to turn the screw anti clockwise enough so that the paddle no longer tings on the bowl.
Once it's stopped tinging put it onto max speed and make sure it still clears at high speed, if not turn the screw until it stops tinging. That's it.
Jan 02, 2018 | KitchenAid K45SS Classic Stand Mixer
The head of the mixer seems to dip to deep into the bowl. It is scraping the bottom and chipping the attachment.
Hi, Put your mixers head in upright position and adjust the screw between the head and the stand. This will rise the head (one rotation is about 1 mm) and the attachement will not scrape the bowl.
Jun 30, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid classic mixer,mixing head comes down to far
flip head up; and, there is a adjust screw underneath. turn screw out ccw to raise head.
Jun 06, 2010 | KitchenAid K45SS Classic Stand Mixer
Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website ( on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Nov 21, 2009 | KitchenAid Food Mixers
Kitchen aid 300 watt counter mixer model ksm90
no there is no adjustment . worn hinge on the base , no parts made , not that i have ever seen ...... sorry i wish i had better news
Jan 05, 2009 | Hobart A200 Stand Mixer
Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Kitchen aid mixer
Tilt the head back and remove your cardboard shim. You should see a screw head. Turning this screw adjusts the beater/bowl clearence.
Apr 13, 2017 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KHM5TB Classic Plus Hand Mixer Logo
80 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
