Question about Jenn-Air JGR8850 Gas Kitchen Range
Oven door squeaks loudly when opening and closing
Jenn-air range oven door squeaks very loudly when opening and closing. Our model is the JGS8860. It does not show up in the list below.
4 Suggested Answers
  • 26 Answers
SOURCE: Jenn-Air electric range
I believe f3 means a bad oven sensor
Posted on Jan 09, 2008
SOURCE: jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Posted on Feb 28, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Jenn-Air free standing range: displays
Hello there
This a common problem with these
F9 Door lock safety circuit on power relay board sensed Replace power relay boardok I would contsact the nearest appliance parts repair center to see if this can be replaced and how much it would cost and mayby you can do it yourself it would save you a lot of money ok?
hope this is very helpful for you
Best regards Michael
Posted on Jan 18, 2010
How can I get rid of the loud squeak in my Jenn-Air oven door?
Digital Camera Battery, Battery Charger Online Store. Canon, Panasonic, Samsung battery and charger online store -http://www.batteries-charger.co.uk is a sincere, trustworthy E-Commerce website since 2006. Provide cheap high-quality replacement battery and charger for Canon, Panasonic, Samsung, like: http://www.batteries-charger.co.uk/ http://www.buy-battery-charger.co.uk/ http://www.gateway-laptop-keyboard.com/ http://www.digital-camera-battery-charger.net/
Jun 08, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn air oven won't open after cleaning. What can
on some models if you unplug it for a few minutes
it will unlock itself when you plug it back in
Oct 09, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air sve47600b oven door hinge
good old 3 in 1 oil or olive oil if none, if problem still there could be wear on hinge
Sep 29, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven door back on
My Jenn-Air oven door also comes off to clean. To remove the door you just open it slightly (to the first position) and lift the door up. To replace it just pull the hinge out about the same angle (about 15 degrees) and slide the door in place on the hinge levers and close the door.
Apr 29, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air- model # SVE47600B
I was cleaning the oven and leaning on the oven door and now when I close the door it is hard to close
Dec 20, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Oven door will not unlock.
You will not be able to open the door if you turn off temp gage. Return the temp gage only to clean and door should open.
Dec 13, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JGR8850 Gas Kitchen Range Logo
119 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
