Question about Toshiba Satellite P105-S6227 Notebook
I can't get the pc to boot up...or get online.
SUReg create key failed.
  • 370 Answers
Reload the operating system from the recovery disks supplied with the laptop, or from the imbedded recovery system hidden on the hard drive. You will have to check your owners manual to see which you have to do. It will explain the process.
Posted on Mar 12, 2009
My option to reset my password does not work. What can i do
If you lost, didn't create or your password reset cd is damaged, try contacting microsoft support or check their KB articles. PW's are usually case sensitive. If that fails....
Do a search for UBCD4windows or Hiren's BootCD
Download the ISO and follow directions to burn to a CD/DVD (create a bootable disk or USB key). You will need a valid XP sp2 install disk as well. Boot from the cd or USB key and use the utilities provided.
Jul 06, 2014 | Computers & Internet
DC7600 Wont boot from win 2003 CD
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
Hope this helps
Dec 09, 2012 | HP DC7100 PC Desktop
OXCOOOOOOF I was doing disk partition
Grab a copy of :
EasyBCD is NeoSmart Technologies' multiple award-winning answer to taking control of your bootloader. EasyBCD extends and revamps the Windows Vista/Windows 7 BCD bootloader, and with EasyBCD, almost anything is possible. Setting up and configuring a dual-boot between Windows 7, Windows Vista, older versions of Windows such as XP & 2003, Linux, Ubuntu, BSD, and Mac OS X is a breeze. You just point & click and EasyBCD does the rest.
EasyBCD is geared for users of all kinds. Whether you just want to add an entry to your old XP partition or want to create a duplicate for testing purposes; if you're interested in debugging the Windows Kernel or septuple-booting your seven test operating systems, EasyBCD is the key.
  • Boot into XP/Vista/7/Ubuntu/OS X and more!
and if :
Your "BOOT" folder has been deleted, was not created, or has been corrupted; and the Vista bootloader will not show.
Solution Boot into a working copy of Windows and install/run EasyBCD.
Go to the "BCD Backup/Repair" page:
Select "Re-create/repair boot files" then "Perform Action" to begin recovery. EasyBCD will recreate (if possible) your boot files and re-configure your bootloader from scratch.
If EasyBCD fails, that means a process has locked your BOOT folder. Manually delete this folder with a Live CD, recovery console, or other method, then try Type Three again.
Dec 11, 2010 | Toshiba Satellite P205-S6287 Notebook PC
I m lookin for installing dual boot with Vista ultimate n Windows 7, gotta dvd for both, any help??
If you wan to fresh install, here you can do ::
Try following steps.
Restart the PC, Press Delete for some time
It will lead you to BIOS setting
Go to the Boot Priority menu,
select DVD ROM as First Boot and HDD as Second Boot
Now Insert your Operating system CD: Vista Ultimate
Restart the PC and when screen says " Press any key to continue"
hit "enter"
Let the CD load and then select New Installation
Format the drive by pressing L, and then create three partition , 100 GB for Vista Ultimate, 100 GB for Windows 7 and rest for data.
Hit enter and let os Load
After complete OS loading, system will restart and again you will see " Press any key to continue"
DO NOT PRESS ANY KEY.
OS will boot and register it with microsft. create login and then remove OS DVD,
Insert the Windows 7 DVD
restrt the system, Hit enter when it says " enter any key to continue"
select new installation, point to the earlier created partition for windows 7 installation
proceed with same procedure.
after complete installation, when you restart the pc, you will find both the BOOT entries at booting.
do not forget to load device drivers on both the OS.
Enjoy!
Sep 07, 2010 | Acer Aspire 5610-4648 Notebook
My computer is stuck at: User profile service failed to logon, user profile can not be loaded. And where do I obtain Password Reset Disk (G:)
sounds to me like you have a corrupted user profile. Boot the computer in safe mode using the F8 key at startup. go in and make a new profile as an administrator. secondly. password reset can be done through boot disk tools called "bartPE" or "ultimate boot disk" you will need to download an ISO from the net and create the CD.
Aug 29, 2010 | Computers & Internet
My hp zd8000 is not rebooting and been told i need a new motherboard
Before you start thinking about your motherboard, let's rule out your harddrive.
Go online and Google "emergency boot cd" and choose a product that works for you. Many have "demos" you can use with limited capability, but that's fine. You will need to take the .iso file and burn a CD with it. This will create a bootable CD.
You will need to setup the computer to boot from a CD by going into BIOS and setting the boot sequence to CD first. If you don't know how to do that, here's a good article...
http://www.cites.illinois.edu/security/antivirus/bios.html
Using your newly created CD, put it into CD drive and start boot up. If your computer boots normally, you have a harddrive tht has failed. If not, you may have a motherboard issue, or possibly a different hardware issue that may require professional assistance.
Oct 22, 2009 | HP Pavilion zd8000 Notebook
I have forgotten my password onto my computer and cant unlock it
If you created a boot disc use this to re-boot your m/c in safe mode using the F8 key,otherwise create a CD using a program like Active Password Changer Professional(£31 from password-changer.com). Or you can always take to your local PC doctor!
Oct 04, 2009 | Computers & Internet
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Sony laptop VGN-N130G will not boot.
use any windows xp disk boot from it and use R key to repair windows then type fixboot
if helped rate fixya
Jan 05, 2009 | Sony VAIO VGN-N130G/W Notebook
Fails to boot
You might try a Hirens Boot CD, un-zip the files, create a bootable cd from the .ISO file and boot your troubled system, select virus scan on boot.
Apr 16, 2008 | Gateway MT3705 Notebook
Open Questions:
See all Toshiba Satellite P105-S6227 Notebook Questions
Toshiba Satellite P105-S6227 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
