Question about Motorola Mobility RAZR V3
Mms messaging someone sent me a picture but it wont open because it says "mms setup is incomplete" how do i complete it and see the picture?!
0 characters
1 Points
My motorola v3 has a message saying mms setup is incomplete, when someone tries to send me a picture......what does this mean
It means that the settings on your phone are wrong. Each service provider has different MMS settings. Call customer service for your company and they can send the right settings to your phone. Alternatively, try the service provider website, sometimes you can set it up using instructions online.
Apr 08, 2009 | Motorola Mobility RAZR V3
Can not Send MMS Texts
hi you need find the MMS directory in the phone, usually in the messages directory and complete it, the settings are:-
Access Point Name:
Username: user
Password: one2one
Authentication: Normal
Data bearer: GPRS
Gateway IP (proxy) address: (also
Session mode: Permanent
MMS Message (Relay) Server URL:
Mar 28, 2009 | Cell Phones
Unable to send/rec pictures SE W850i
I think the problem here is with your connection. I understand that you have the right settings from your operator...however you should check with them to see if your line is data enabled for MMS (this is how your pictures are an MMS message).
Feb 22, 2009 | Sony Ericsson W850i Cellular Phone
That phone doesnt support mms because its not mms compatible, go onto that website on a computer to access the mms someone has sent you.
You can only recieve texts and text pictures such as :) and :P and pictures drawn with dots and @....
Oct 02, 2008 | Nokia 1110 Cellular Phone
MMS setup
You will need to take the phone and have them setup you MMS manually...or you can contact OPTUS Customer service line and have them assist you.
Sep 06, 2008 | Motorola Mobility RAZR V3
Razar v3xx
When you receive the message with id and password, it usually means that either your phone is not multimedia messaging compatible or your account is not provisioned with the actual multimedia messaging feature itself.
If unable to send or receive a picture message (MMS), troubleshoot accordingly:
  1. Attempt to connect to MEdia Net on the device. Connectivity to MEdia Net confirms the device has enough signal strength and GPRS availability to send and receive MMS.
  2. Verify MMS is being sent to an AT&T subscriber. If MMS message is being sent to someone other then an AT&T wireless services subscriber, verify that the carrier is supported.
  3. Picture messaging settings are pre-configured on all devices purchased from AT&T. If the settings have been altered or if the device was not purchased from AT&T, validate picture message settings are properly configured.
  4. Attempt to send an MMS again.
  5. If further assistance is required, please contact Customer Care.
If problems occur, please perform the following troubleshooting steps:
  1. Verify device has signal strength.
  2. Check for a GPRS attach on the device.
  3. Verify the browser settings are correct.
  4. Clear the browser cache.
  5. Power cycle the device (turn off and back on).
  6. Attempt to access MEdia Net again.
  7. If unable to access a particular MEdia Net site, check to see if the site is supported by AT&T.
  8. If problem persists, please contact AT&T Customer Service for wireless customers.
Jun 08, 2008 | Motorola Mobility RAZR V3
Picture messaging
You have to set up the gprs and mms settings. Go to the sony site, pick your region, then choose support and choose the gprs and mms setup. The settings will be sent to your device right from thier site. Hope this helps.
Jan 24, 2008 | Sony Ericsson W550i Cellular Phone
MMS settings for W850i
Do you have the MMS message server configured properly?
Dec 15, 2007 | Sony Ericsson W850i Cellular Phone
I dont know how to set up my phones MMS and GPRS.
YakYak, Go onto your network providers website register on there, and there should be a option once you have signed up, confirmed your email address etc... You should Be able to set it up for MMS & GPRS, hope this works and good luck.
Oct 12, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility RAZR V3 Logo
136 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
