Question about Kenwood KDC-MP735U CD Player
Whistling when i start my truck, a high-pitch whistle comes out of my front tweeters. i have a factory bose system and i upgraded the headunit to the kenwood kdc-mp735u and a PAC interface, c2r-gm24. the bose has a built in amp. the whistle seems to be in-tune with the rpm's, like it goes up and down with the rpm's. what is causing the problem and what is the solution?
  • rupert farnsworth Aug 03, 2007
    ive tried grounding it in different places, that doesnt seem to help. what is the B+ wire?
    Brigadier General:
  • 6,966 Answers
Hi, A couple of possible cause: 1. alternator whine - installing a filter (capacitor/inductor) in series with the B+ line to all the electronics units; 2. grounding - possibly insufficient grounding considering that you gave different brands and are interconnected; check/improve grounding, It is also helpful to install a unit chassis mounted grounding to all the units going to a common ground lug; 3. audio line level input wire too close to a B+ line - move further apart or improve shielding of signal wire; 4. loose battery connection - (although unlikely) worth to check; 5. power on line (sometimes color yellow sometimes blue) - needs filtering (a possibility only but worth to check by connecting to mains B+ instead of via ignition switch. of course this will defeat ignition switch activation of unit) A reminder, pls make sure your voltages match up chances are your electronic units are 12 volts and your truck (big truck?) might be, just might be 24. It is another issue when your truck is 24 and your units are 12, If so check your 24 to 12 DC to DC converter. Hope this gives you some idea and work out for you. pls post again how things turn up. Good luck and kind regards.
Posted on Aug 03, 2007
  • Louie  Role
    Louie Role Aug 03, 2007
    Hi again,
    B+ line is the main (usually big red wire) supply of your units. Chances are it is directly connected to your battery positive pole via a fuse. Tracing/checking where this wire leads to will help you find out any loose connection. For example from your amp or stereo, this wire will pass a fuse holder, then ontowards a junction box or where all the other wires meet, then it will either go to the ignition switch of your truck or to the engine compartment, there it will go to a fusible link before finally to the positive terminal of your battery (assuming 12v).
    Off hand, experience has taught me that this kind of noise is alternator whine which can be resolve by installing an electrical/electronic filter to remove any noise in the B+ line.
    If the whine is both present in either FM or CD mode, then big chance it is B+ noise, if it is only during FM, you might as well check your antenna grounding.
    Pls post again how things are and/or if you need further information.
    Cheers.
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
How do I get rid of high pitched whistle in cabin air system?
blower motor might be going out. worn out bearings.
Jun 28, 2014 | 1998 Toyota Camry
2011 Avalon high pitched whistle
I had that , and it was the transmission low on oil. Hope this helps.
Mar 20, 2014 | Toyota Avalon Cars & Trucks
My brand new Whirpool front loader 1073DD makes a high pitched whistle when starting to spin and spinning, is this normal?
That actually is a normal sound, The machine is spinning at such a high speed rpm that a whistling noise is a common occurence.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 14, 2012 | Whirlpool Washing Machines
Whistling sound form tweeters
The unit is picking up noise from the electrical system of the vehicle--power is either connected to the wrong place or a noise filter needs to be inserted at the voltage source for this equipment.
Apr 23, 2012 | Infinity Speakers Infinity Reference 1031t...
My 2005 ford freestar has a high pitched "whistle"
I am having this same issue. I have changed my brakes and now I was going to change the front wheel bearing, but unsure to dump a lot of money out on an unsure fix.
Let me know if anyone has a fix?
Feb 20, 2011 | 2005 Ford Freestar
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
Jun 23, 2010 | Maytag Ovens
High pitched whistling
Try changing refresh frequency, color depth or resolution (wait for the whistle to appear before testing). Admittedly, you might have to give up some image quality - less colors, or less resolution. There is probably a problem in the TV syncing mechanism - if you can, try getting it replaced. "High pitched whistles" in video and TV hardware are usually harbingers of bad news.
Aug 24, 2009 | Samsung SyncMaster 245T 24 inch LCD...
When i give my car gas a whistle comes from the engine. It's a high pitch continual sound. When i let off the gas the whistle stops. It sounds like it's coming from the top of the block.70k miles...
Sounds like a vacume leak, chk. for a cracked or broken vacume line or maybe one came off. Does it idle ruff? With it running open hood and listen for a low pitch whistle you may have to rev it up a little.
May 31, 2009 | 1986 Ford Thunderbird
Kenwood KDC-MP735U CD Player Logo
90 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
