Question about Honda Maxus Pressure Washer MX5222
How to change oil in honday power washer 2500xl
Does the 1994 Honday Accord have a low oil sensor that shuts the engine off when the oil gets to low to stop damage
Not that I know of. If the oil pressure drops to less than 10psi the fuel pump will stop getting power.
A common problem with Honda cars is the fuel pump relay but that would not have anything to do with the oil.
Jul 27, 2012 | 1994 Honda Accord
I am trying to chang the oil in my 2100. and i've turned the yellow pice at the bodom and i still have oil in it.
You cannot empty oil completely out of a power washer without a suction hose
Do not turn the power washer on its side or upside down or oil will run into carburetor
The pump oil comes about half way up dip stick >>> use SAE20 or SAE30 non detergent motor oil
The engine oil comes about half way up dip stick >>> use 10W30 for engine
Oct 16, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
How many ounces or quarts of oil do you put in the engine and what kind when changing the oil?
Power washer needs oil 2 places.
The pump head has a plastic window on side of pump. Oil should fill to middle of that window. Pump should have 20 or 30 weight NON detergent oil. SAE20 SAE 30 I believe. Auto parts store will know which is NON detergent.
The engine oil is ordinary 10W30. We used to change oil after each painting season by tilting engine to the side. Do not turn engine on it's side or upside down or oil will run into carburetor.
I don't remember exactly how many quarts we put back. Maybe 2? Fill up reservoir until oil is about half-way up dip stick.
Oct 07, 2010 | Simpson PowerShot Commercial-Duty Gas...
Hi, what kind of oil can i put in my ridind lawnmower craftsman?
The domestic engines (Briggs, Tecumseh) take SAE 30 weight motor oil. The import engines (Honday, Kawasaki) usually take 10W30 motor oil. In either case, I recommend using a good quality name brand oil like Castrol, Pennzoil, etc. Most riding mower engine take about 48oz from a complete drain. If your engine has an external filter, it might require a few more ounces.
I hope this helps.
Aug 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How often do I have to change the oil in my 2005 Honday Odyssey? The manual doesn't specifiy clearly. Should I just go by what the oil gauge on the dashboard tells me?
3months or 3,000 miles is the traditional, however with the heat these newer motors generate if you do a lot of in town driving I would recommend around 2,000 miles to help prolong the longevity of your engine.
Jul 27, 2010 | 2005 Honda Odyssey
Just bought new 09 honday goldwing and noticed I have an oil leak which seems to be coming higher up maybe like around engine anything on this?
It is frustrating to stop an oil leak if you don't find the correct source of the problem. This might be due to poor valve and cover gaskets.The back hole might have some sludges or became restricted due to improper choice of oil and due to lack of oil change.
May 20, 2010 | 1995 Honda GL 1500 SE Gold Wing
What viscosity oil is recomended for oil change?
  • Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
May 24, 2010 | Karcher G 2600 VH Gas Pressure Washer
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Transmission noise
Washers normally don't have much grease in them at all....the transmission is full of oil....which on GE washers often gets dumped onto the floor.Remove power, tilt the washer back and check on/around/near the large center pulley under the tranny....often the belt and pulley throw the oil around inside the cabinet.
Some of the oils they use are a synthetic oil....acts a little diff than some other oils....sometimes if water gets into the tranny the oil can change foamy or black due to the moisture.
Feb 10, 2009 | GE WHRE5260E Top Load Washer
Honda Maxus Pressure Washer MX5222 Logo
29 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
