Question about Watches
Relic auto wind watch zr77133 stopped working? How do I get it going again?
2 Suggested Answers
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
I have Relic VX3J 3 Eye - stopped working after 2 years.
If turning the adjustment bead does not result in a clicking then it is likely quartz. I am presuming it did not require winding. So if it clicks and comes back to life it is automatic (just wear it to charge it) if not then it is likely quartz. Most automatic watches can also be manually wound to charge. This is better for the movement when it is fully unwound, 10 full turns to be on the cautious side from flat. It is unlikely you can overwind good quality modern watches as they have a clutch to prevent over winding. cheaper watches may or may not have this feature.
Mar 22, 2014 | Relic Watches
Relic watche zr11853 automatic is not working. No movement in the skeletal innards but the dial works if pulled out. There shouldn't be a "battery correct?
the RELIC ZR11853 is an automatic movement (spring) you have to rotate the crown to wind the spring,
the Automatic part is, when its worn on the wrist, the movement of your arm swings a small weight in the watch that winds the spring.
May 25, 2013 | Watches
Watch stops
It needs a watchmaker. Needs cleaning and or replacing of oil... good luck!
Dec 05, 2011 | Watches
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know...
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Oct 14, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
I have the Relic with the pink face which stopped working. The watch repair at Sears said not the battery, it's the mechanism & wanted $60 to repair. Can I send it back to Relic?
<P>Thank you for cxontacting FixYa.</P><P>You can send back to Relic. I dont know how long you have had, as they do have a 12 yr warranty but you will have to see what restrictions they have on it.</P><P>You can find this info at:</P><P><A href="http://relicwatch.com/warranty.htm">http://relicwatch.com/warranty.htm</A></P><P>Best wishes. Jewel</P>
Aug 27, 2010 | Relic Glitz ZR11778 Watch for Women
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
Apr 16, 2010 | ORIS Watch TT3 Day Date 63575887067MB
I replaced the battery in my relic watch and can't get the cover to snap back on. I have the notch lined up with the wind and it won't go. Is there a secret to this?
The answer is probably "yes".
Don't try too hard (as backs can be damaged); take it to a watch shop and ask them to sort it out for you.
Feb 22, 2010 | Watches
Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Feb 09, 2009 | Relic 0504648FA
Watches Logo
184 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
