Question about Exercise & Fitness
Belt slipping Hi There, I have a lifegear walkease manual treadmill. I need to know where I can get a copy of the manual and how I can fix my belt so it doesnt slip to the right and scrape against the gear wheel while I'm walking on it.
  • 83 Answers
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
How do i fix a lifegear treadmill 97520?
Try below:
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Lifegear treadmill
You might inquire of Lifegear how many watts it consumes
Jun 04, 2013 | Exercise & Fitness
Agent in bahrain.
you must contact to the company supplier for the treadmillss and ask who is the dealer around you. Give you moder, mark, and serial number
God bless you
May 30, 2013 | Exercise & Fitness
I need the I.C number on a Lifegear Walkease Motorized Treadmill # 97295, found out the ic was burnt on the control panel whicl always display E2 code
Dear Sir:
1)In electronics, you must need to get the number of IC.
2)If you get some information like as the number of the Control Panel, will be more easy to find, the I.C.
3) You must shure the why the I.C. was burn? . Normally this problem can occur a) failure for some short of some component around the I.C. b) Power supply +5 or 12 Vdc or Low or Higher( Indicating that power supply is Not Good).
4) Would you please tell the exactly Model, Mark, Serial from your Treadmill? In that way I can help you more, and try to get the Schematic Diagram from your Fitness Treadmill.
Sincerely. God bless you.
Oct 24, 2011 | Exercise & Fitness
How do I fix a problem with the belt slipping?
hi there
it could be 2 things of this problem
1 walking belt slips easy ti fix
1th step; put treadmill in speed of 4 mph and step on side and try with one leg to stop it (be carefull) if you see walking belt stops with align key give more tension from the back of treadmill rear rollers by turning both bolts clockwise same degree with small turns till stops
if it does not help it is probably drive belt
you need give more tension on motor by using 9/16 wrenches
Nov 22, 2010 | Proform Sport 1000 Folding Treadmill...
Our Treadmill belt is slipping. How can we fix it?
hi, if the belt is slipping you need to tighten it, at the back end of the treadmill on the corners there should be two bolts turn them both untill you can only lift 2 to 3 inches of the belt up,
Nov 22, 2010 | Epic View 550 Treadmill
Belt seems to slip while on the treadmill
hi your belt need to be tightened, check your manuel on how to do this. but do not walk on the belt when its doing this you can damage the belt and the motor very expensive to fix.
Nov 11, 2010 | Proform Crosswalk 500 Treadmill
The walking belt jars when running fast. Also I want to know how to lubricate it. Anyone with a manual? Please help?
Follow the directions below to determine what is slipping. You also can get a copy of your manual by going to and downloading one from the manuals tab. Here are the directions for testing the slipping problem.
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
Aug 24, 2010 | Proform Exercise & Fitness
Owners manual for lifegear manual treadmill
I have a lifegear treadmill and get an E2 error and the treadmill will not move.
Aug 19, 2010 | Exercise & Fitness
How do adjust tension on treadmill belt
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 27, 2010 | Exercise & Fitness
Exercise & Fitness Logo
595 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
