Question about Earthwise CST00012 18-Volt 12-Inch Cordless String Trimmer
How to rewind line earthwise string trimmer - Earthwise CST00012 18-Volt 12-Inch Cordless String Trimmer
How do you rewind the string on the black and deckder grasshog
It's annoying I know, but there should be a little notch in the spool, wind the string evenly round one groove. notch it, then do the same on the other groove but in the opposite direction. Hope this helps.
Jun 28, 2015 | Black and Decker USA BLACK&DECKER GH710...
Poulan25cc 16 inch how do i rewind trimmer line on my poulan 1500 gas trimmer
You should wind it on the spool the opposite direction that it spins while operating it. If you wind it in the same direction as the spin, the line will come off the spool when in operation.
Jim
Jul 29, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
After going through at least 3 string-type lawn trimmers, I have yet to find one that can actually feed the string. I have used Black & Decker, and most recently, Toro 8" cordless, with the same...
This can and is a frustrating problem. Some things that help are to be sure to use the right size of trimmer line. Be careful when rewinding the reel to not twist and cross the lines. I realize we should not have to give this much attention to it, but until somebody "builds a better mousetrap", we only have so much to work with.
May 15, 2010 | Toro& Electric String Trimmer
Line will not advance line is not crossed in spool
Rewind the line and make sure you wind in the direction of the arrow on the spool. Not an unusual situation.
Mar 31, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Can't find replacement string?? And can't seem to figure out for sure the model # or # on the string?
Most line trimmers will take .065 line. you can get this at lowes or home depot. Be sure to rewind it in the direction shown on the spool.
Aug 30, 2009 | Garden
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Earthwise CST00012 18-Volt 12-Inch Cordless String Trimmer Logo
62 people viewed this question
Top Earthwise Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Earthwise Measuring Tool and Sensor Expert? Answer questions, earn points and help others
