Question about Guest 503 Spot/Flood With Console Control
My guest spot flood light will go up but immediately goes back do
My guest spot flood light on my boat will go up when holding down the button, but when you release the button it goes straight back down by itself, i have upper and lower controls.how do I repair this problem?
1996 70 hp johnson outboard ,,need to know why the motor rise up when I put it in reverse and give a little speed to back up, and when I let off the speed the motor goes back down.
In reverse, the propellor is pulling the motor away from the boat, this is the same direction as the motion you get when you tilt the motor up for transport. Check the motor mount, especially the motor tilt mechanism to make sure nothing is excessively worn, bent or loose. Maybe the latch that's supposed to hold the motor in the run position isn't working right - that could be bad news if it lets the motor drop down while the boat is on the trailer.
Jun 26, 2015 | Boating
I have an HP laserjet 1320; all of a sudden I cannot duplex print...it will print one side only and on the reverse side of the page I get a message: Guest: ERROR: MemoryFull Guest: OFFENDING COMMAND:...
Welcome to Fixya
Try to restore the printer to factory state and make sure you record your printer's settings before performing this procedure. Holding down the printer's Green print button briefly will print any configuration information.
a. Turn the printer power off
b. Press and "hold" the green "go" button whilst turning the printer on.
c. Continue to hold the go button for at least 5 seconds and until the amber
attention light turns on (triangle with ! in the middle), this should occur
before 15 seconds elapses.
d. Release the go button.
Your response will be highly appreciated.
Thank you for using Fixya!
Jan 04, 2011 | Computers & Internet
Iphone 2g not starting back up after reboot..
When the device is locked up like this hold down the lock and home buttons. After a few seconds the device will turn off, immediately let go of both buttons. Now press down and hold the home button. Hit the power/lock button one time. Continue holding the home button until the phone boots up. It will need to be connected to iTunes for recovery at this point.
Jan 27, 2010 | Apple iPhone Smartphone
My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Jun 19, 2009 | liftmaster Chamberlain Garage Door Opener...
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Hi, I purchased Thomson TG585 v7 ADSL2+ Modem/Gateway yesterday and I imported old modem configuration to it and immediately it stops responding. Cannot reset to factory defaults (by reset button too) or...
With the unit powered on perform hard reset back to factory settings. Use a paper clip to push the reset button on the back panel of the modem. Hold down for five to 10 seconds. Release when the power light goes red
Oct 02, 2017 | Computers & Internet
Flashing power button
Depending on the number of flashes,it could be a power supply or y-sus board.Both parts are silly money.The flashing light indicates a fatal startup error.These units make a great boat anchor for a 16ft boat.
Mar 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Guest 503 Spot/Flood With Console Control Logo
91 people viewed this question
Top Guest Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Guest Boating Expert? Answer questions, earn points and help others
