Question about Hitachi 43UWX10B 43" Rear Projection Television
Hi! This TV is a 43UWX10B. I have a double picture (one on top of the other)1 green and 1 pink. Skin tones - pink and green. No white, it is also pinkish. Black color is good. Other than the problems the TV works very well. I hope this is enough information. Thanks, Bill
  • 6,784 Answers
Hi, there are two issues here. the deflection board is not working properly. the second issue is the convergence board. its totally out and i recommend replacing the entire board. there are two ribbons that lead from the power supply to the deflection board and this convergence board. check these for separation. there is also a signal board in this cluster as well but, I'm not sensing anything wrong here but, it wouldn't hurt to check the board for discolorations. Take care of those issues and you will have your set back to normal operations. Of curse, these repairs are not cheap but, it will bring the tv back.
Posted on Mar 12, 2009
    Sergeant:
  • 254 Answers
Its the problem of convergence ic and the tv needs reparing of the ic urgently to solve the issue and avoid further colour damage.
Has pink/green horizontal line across top l corner
Hi,if your tv is dlp or lcd you will need to replace the light engine that's in charge of creating the image and colors, and when bad you 'll get discoloration or lines across image.
Oct 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Tv has double image at top of screen..can cover green lens and double image goes away.what can cause this and how can I repair?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Pink and green lines and double picture on Samsung big screen tv.
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
Jul 08, 2009 | Samsung LN40A650A LCD TV
Lost manuel to canon powershot A630 and I wanted to know how to take a black and white picture.
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
  • ISO speed (Auto, High ISO Auto, 80, 100, 200, 400, 800) -
  • White balance (Auto, daylight, cloudy, tungsten, fluorescent, fluorescent H, underwater, custom) -
  • Drive (Single-shot, continuous, self-timer [2 or 10 sec, custom] -
  • My Colors (Off, vivid, neutral, sepia, black & white, positive film, lighter skin tone, darker skin tone, vivid blue, vivid green, vivid red, custom color) -
  • Flash exposure compensation (-2EV to +2EV in 1/3EV increments) - in manual mode you can adjust the flash strength in three steps (1/3, 2/3, full)
  • Metering (Evaluative, center-weighted, spot)
  • Compression
  • Resolution
- Lisa
http://www.dcresource.com/reviews/canon/powershot_a630_a640-review/
Feb 26, 2009 | Canon PowerShot A630 Digital Camera
Pink and green with double writing
this is a internal problem you should call 1-888-PHILIPS (744-5477) to set up service. It is usally a main board problem
Jan 08, 2009 | Philips 52PFL7432D Television
No pink tone in skin tone
are you using genuine or compatible cartriges?
never use compatables for photos - keep them for documents etc
Nov 18, 2008 | Canon I900D InkJet Photo Printer
Hitachi tv
You need to call a tv repair person.The set needs new convergence ic's an updated resistors.This is a common failure and they have a update kit to help increase performance.
Jul 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Jul 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
53HX71 showing lots of green
im thinking blue lamp if whites look pink thats telling me theres not enough blue.
Dec 05, 2007 | Toshiba 53HX71 53" Rear Projection...
My tv sucks help me
Ryan, this sounds as if the green CRT has gone out in this set. You might want to double check the warranty of your television as this set might have a lifetime warranty on the CRT's. If you cannot find the warranty info on your set, call 1-800-448-2244 for further assistance
Nov 16, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
