Question about Hannstar I-Inc TW-191D Monitor
Problem is back to black monitor - Hannstar I-Inc TW-191D Monitor
Monitor gos black turn off then back on video stays on 15 sec then off again
Hello
It could be a bad monitor or videocard ,the only way to test this is by connecting another monitor to that PC or your monitor to another PC.
Good Luck
Feb 13, 2012 | HP Computers & Internet
Monitor does power up but no picture??
heck342, Your monitor may have the common "black screen of death" that will occur to ANY AND ALL cold cathode-fluorescent-lamp, back-lit, lcd monitors sometime during their lifetime. You will need to do a lot of reading in my fixya profile and those of "buddymc" , "budmrtn" and then you will understand what you will or will not do with your unit. I'll even bet you haven't been to YOUTUBE to view any DIY repair videos yet! Come back here for more info after you do a little research on the WEB, and can tell us tech's that you know the difference between a "black screen" and a "blank n black screen" monitor. Remember this, your CCFL back-lit lcd unit" design and principle of operation isn't any different than any other brand. Have you done the "flashlight test" that every CCFL back-lit lcd monitor owner should know how to perform and interpret the resulting info when black screen of death occurs? Bye for now. 12fixlouie
Jun 13, 2010 | X2Gen MG19MY 19" LCD Monitor
AOC LCD monitor black out..Please help? I'm having some problems with my monitor, from time to time my monitor just blacks out, the whole screen turns black, but the computer is still on....and i'm forced...
Sounds like bad video card drivers..Try updating the drivers from the manufacturer's website. Give us the details of your video card/ PC.
Or it could be monitor related. Open the monitor and check the power supply. Make sure there are no bad capacitors inside. If you find any replace them with new ones with same number or bigger capacity,
Apr 02, 2010 | AOC LM720 17" Flat Panel LCD Monitor
How com monitor blacks out
I am not sure I am fully understanding your issue...but monitors require power to operate.
Good Luck,
Jesse
Jan 06, 2010 | Star Logic Monitor 11009515
No picture on the monitor
try to log into safemode, change the setting of your monitor or install the vga driver if its needed.
Jun 17, 2009 | Hannspree HANNS G HW191DPB (Black) LCD...
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Monitor goes to black and back on
MY LCD 22 ACER MONITOR GOES O BLACK AND I CAN'T SEE THE MENU
Nov 21, 2008 | Acer 22" X223w LCD Monitor
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Oct 03, 2008 | Computers & Internet
Monitor black out
try to adjust the setting of your video and refresh rate
Mar 12, 2008 | Videoseven V7 R19WPS 19" LCD Monitor
LCD Monitor blacks in and out for 1-2 seconds
does your monitor have an external transformer as the psu ?
If so, try disconnecting at mains for about 5 seconds and re-connect. failing that we'll need to dig deeper.
Jan 06, 2008 | Samsung SyncMaster 205BW LCD Monitor
Hannstar I-Inc TW-191D Monitor Logo
21 people viewed this question
Top Hannstar Computers & Internet Experts
David Payne
David Payne
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
