Question about IBM ThinkPad R32 2658 Notebook
R32 thinkpad no longer boots to bios ,windows got blue sreen
Blue screen said firmware problem .now when trying to turn on only cooling fan goes at various speeds.
  • onita511
    onita511 May 11, 2010
    Here is some great source to solve any kinds of laptop's problem.
    » Hp Laptop's Solution » Compaq Laptop's Solution » Acer Laptop's Solution » Dell Laptop's Solution » Toshiba Laptop's Solution » Asus Laptop's Solution
    » Gateway Laptop's Solution » IBM Laptop's Solution
    Here is some another Great source to download any kinds of laptop Drivers.
    » Hp Driver's Download » Compaq Driver's Download » Acer Driver's Download » Dell Driver's Download » Toshiba Driver's Download » Asus Driver's Download » Gateway Driver's Download » IBM Driver's Download ami-67
Laptop turns on, goes to first screen which reads IBM TRHINKPAD. THEN FLASHES OFF TO NEXT SCREEN WHICH READS THE WINDOWS XP LOGO then it goes black and doesnt come back on
Your installation of Windows is most probably corrupted. Try pressing and holding the F8 button on your keyboard when the 'IBM THINKPAD" screen disappears. That should bring you to a Windows menu where you can select various modes. Select Safe Mode and press enter. If it boots, then you know that something's wrong with Windows and not the notebook itself. What have you installed prior to this problem? Maybe you should try uninstalling it while in safe mode, and then try starting up Windows normally again.
If your windows doesn't start anyway, you should get some live OS (OS that can boot from CD) like Ubuntu or Puppy Linux, so you can save the data from C: partition (burn it or copy it elsewhere) and then reinstall your copy of Windows XP.
Sep 01, 2011 | IBM ThinkPad R32 2658 Notebook
The ThinkPad 2647 8MU will not restart. After a screen that shows IBM Thinkpad, then a black screen comes up that says: Error Fan Error Press <F1> to Setup. If I press <F1> it...
Your system fan has died and need to be replaced. You can look in your bios for a setting to ignore fan speeds, you may or may not have one depending on your bios. But be careful, if you can bypass the fan error, you risk causing harm to your computer by overheating the processer.
Feb 17, 2011 | IBM (26P9166) Fan Assembly, Cooling Fan
Windows has a .dll boot-up problem, bios is inexecable, can only boot from hard drve and not from any other drive, need too reset bios or something. thanks
hi you can normally reset the bios by locating the on-board battery under the notebook, or by removing the keyboard if it is that model and remove the bios battery for a few seconds and that should clear any settings in the bios including the password to enter it, then replace the battery and re-boot the system , press either F2 or del to enter the bios while booting...hope this helps
Jan 14, 2011 | IBM ThinkPad R32 2658 Notebook
My lenovo t60 screen goes black 15 seconds after
Hi, try to boot into safemode, turn your system on then keep on tapping F8 to get the windows advance Menu screen, select safemode.
In the safemode windows go to Control panel and check your power options, you will see what time frame your system has for the LCD when turning off.
If this does not fix the issue, try booting into safemode with networking for you to be able to go online in safemode try updating your BIOS from your Manufacturers Website, Updating your bios may fix the issue.
Mar 12, 2010 | Lenovo Thinkpad T60 Notebook
ThinkPad Blue Screen of Death
Sometimes the blue screen can be caused by bad memory, but if it is doing it right when you try to sign in every time, it is probably a software corruption in windows. I have solved this problem by doing a repair install of windows xp, I am not sure if is an option on other os, if you google it you will find directions, you boot off the windows install disk and this option saves your programs and data.
Oct 27, 2009 | IBM ThinkPad T22 2647 Notebook
IBM THINKPAD R32 Tryin buttons to boot won't work?
Normally when as you bootup press F12 and you get a list of devices that you can select to boot up.
If the doesn't work go into the BIOS setup and go to the boot order configuration and set the CD as the first boot device. Later you can change it back if you wish.
Jul 12, 2009 | IBM ThinkPad R32 2658 Notebook
My IBM thinkpad R32 takes more than 2 minutes to
Your system may have been attacked by virus. Or your memory is too small for the operating system you are using. If you were not having the problem initially, try scanning the system for Virus with a powerful antivirus software such as Norton. You may also save your important files, format the harddisk and reinstal all software. Better still, your restore the system to a date before problem started if you are using windows vista.
Jun 27, 2009 | IBM ThinkPad R32 2658 Notebook
Restart problem
Can you give me lots of details?
What have you tried so far?
Jun 19, 2009 | IBM ThinkPad R32 2658 Notebook
Boot problem
check it on bios whether the hard drive is detecting or not, if detecting then recover OS using recovery Cd
Nov 15, 2008 | IBM ThinkPad T40 2379 Notebook
ThinkPad R32 Overheating
Its more likely the fan has stopped working. I recommend taking it to a qualified repair shop.
May 21, 2008 | IBM ThinkPad R32 2658 Notebook
IBM ThinkPad R32 2658 Notebook Logo
199 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
