Question about Toshiba 19A25 19" TV
Sound Stuck on High
Mute works fine and the sound goes off if you turn the volume down to 0. As soon as you turn the volume up to 1 it is very loud, as loud as it should be on the highest setting. All other volume settings, from 1 to 64 sound the exact same. This is for every channel.
    Genius:
  • 1,074 Answers
Change the audio ic it has a short within.this will restore your set to normal dont forget to make checks in that same circuit as there might be resistors,diodes or caps that had contributed to the failure of the ic.good luck.
Posted on Aug 05, 2007
SOURCE:
It'll work listening to the radio just fine for about 5 minutes, then the sound goes away.
If you are running at high volume for even a short period of time, the overload signal to the microprocessor(computer within your unit) will cause the unit to shut down. If you are running it that loud, try turning the level to 1/3 of your normal listening mode. If it runs, try to keep the volume with reason.
Aug 04, 2015 | Audio Players & Recorders
Volume stuck on mute for wireless speakers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Oct 25, 2012 | Computers & Internet
I have no sound out of the front speakers. Mute button is off, speakers work fine. Only have sound (very little) if volume is turned way up.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's
full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume
it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape
Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead'
spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate
every control throughout its range a number of times, especially rarely-used ones like Tape
Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jul 10, 2011 | Yamaha RX-V870 Receiver
Hi there, our amp is giving us very low sound output even when volume is turned up to maximum volume. We have been unable to find the remote and are wondering if the remote was turned right down would that...
I'd look at the front panel for the Mute Button and the Mute Indicator, but turn the volume down for any further investigations. If you can't hera the sound at 1/2 volume, it ain't there. No sense risking a sudden volume surge that will kill your speakers when you finally find the problem.
http://www.retrevo.com/support/Harman-Kardon-HK3270-Receivers-manual/id/386bh430/t/2/
Also check the T-Mon Indicator. If it;s on you have the Tape selcted for listening instead of a source.
Volume/Mute Indicator: This
indicator will glow green when the
HK3270 is turned on. Its position
will enable you to judge the relative
volume of the unit even when the
speakers are muted or turned off.
When the indicator is pointing
towards the left, at an "8 o'clock"
position, the volume is low; when
it is pointing to the right, as in a
"3 o'clock" position, the volume is
loud. When the unit has been muted,
pressing the Mute button ïâthe
indicator will flash
Dec 26, 2010 | Harman Kardon HK 3270
32LG30 television, volume too high from level 0 to 1
If you are using a cable box...turn down the sound on the cable box.
Jun 24, 2009 | LG 32LG30 32 in. LCD HDTV
I AM GETTING VERY LITTLE SOUND FROM THE SYSTEM
When did this start? What happened just prior to that?
Turn the volume DOWN for any further analysis. If it isn't loud enough to hear well at 1/4 volume, cranking it to the stops will not resolve it AND when you finally find the misplaced switch you may launch all of your speaker drivers right out of their cabinets.
Do you mean the MUTE button does not CHANGE the volume? It sounds like you're muted already and it doesn't UNmute. Is MUTING lit on the display?
Does it happen with all sources? Use onboard FM to troubleshoot as it can't be connected wrong.
Apr 01, 2009 | Onkyo TX-DS575 Receiver
PRIMA 32" TV
if you know how to solder, try to solder the system ic an the sound ic but be careful of short circuit.
Jul 11, 2008 | Prima CV2011 TV
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Volume
Hi the volume is just a big fuzzy sound. You can listen to anything. Mute button does work and volume adjustment does work. No Sound at all other than fuzzy sound.
Jan 07, 2007 | RCA 32F531T 32" TV
Toshiba 19A25 19" TV Logo
289 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
