Model # 178A50-1B Ser.# 12232973 UT# 03599
SOURCE: Need service manual for Homelite 16
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
SOURCE: i have a walbro hdc 39 carb. thats need to be
This place has the kit you are looking for
NEW Walbro Carburetor Kit OEM K10-HDC
http://stores.ebay.com.au/Bartz-Mower-Service
Testimonial: "thank you "
SOURCE: Our Homelite model 5500 generator
The problem when that happens is usually a loss of residual magnetism...by flashing the generator you can recharge the permanent magnets, and then the generator will work again.
Generator Flashing
This link gives one way to do it.. there are others if your google it...look a few posts down to find the procedure...
heatman101
SOURCE: Seeking an operator's manual for
The only way to get the manual for your generator is to contact homelite on the link below.
https://register.homelite.com/contact_us/new
SOURCE: Homelite 6000 Generator running rough, now won't start
i have a solution, i have a homelite in my motorhome and for 3 years it is a slowly failing hunk of junk, dump the homelite generators and find a better more quality generator, not a cheepo thats y they fail so much.
