Question about Sony STR-V444ES Receiver
Sony V444ES Receiver
Hi.. Having issues turning on the receiver with the remote. It just "clicks" for about 3-5 minutes, then gains power. Once it gains power, it seems to be OK, but I run EVERYTHING through my receiver (Sat, DVD, VCR {yeah I still have one}, XBox, etc.). When it won't turn on, neither will anything else!! Thanks for your help. RE
Ours started doing this also now up to 20 min of clicking before it turns on.  My thought is that it is a bad power supply since once its on it works fine.
Posted on Aug 04, 2008
  • john mangrum Dec 06, 2011
    mine also started doing this about 3 months ago..just the other day, it did this so long ,i attempted to cut it back off via switch but it wouldn't respond & just kept on clicking..I eventually had to unplug & replug several times before it became normal & afterwards worked just fine..I dread cutting it off though because I;m uncomfortable when this happens as I cut it on sometimes..This issue makes me feel as though something inside is about to seriously get damaged..
SOURCE:
Power
Set the harmony remote to switch the pioneer first, then the rest of your stuff.
Feb 06, 2014 | Pioneer VSX1020K Receiver
What's your problem?sony v444es 5,1 wont turn on, only clicks the relay on power board non stop
Sounds like your power transformer is bad. You might also check the power board for cracks. This model had a history of that.
Jun 21, 2012 | Sony STR-V444ES Receiver
Hi - I have a Sony V444ES receiver that I have four speakers on A (in house) and two on B (outside). I hooked up a third speaker (rock speaker) for outside use however the sound is very low compared to the...
What's a rock speaker? All you will hear with one speaker on the Rear Right output is the Rear Right channel which is typically for effects and ambience. You DO have a manual, right?
Individual speakers commonly have different responses given the same amplifier input. Where you physically place a speaker once it's electrically connected is up to you. Speakers placed outdoors might not have the sound-re-enforcement of nearby or adjacent walls as indoor speakers do so they will sound weaker.
Jul 11, 2011 | Sony STR-V444ES Receiver
Hi receiver is having intermittent problems with power up & off. at the moment it would only turn on once in 5 times i try to turn on. At one stage it would turn off but then back on again within five...
I got Yamaha RX-V3800 with intermittent power.
Cause by capacitor C4 22nF 630V on the control power board.
After replacing the capacitor, receiver again working OK!
Feb 13, 2011 | Yamaha RX-V3800 Receiver
Receiver str-v444es no sound on headphones or
discharge the output circuit! If you don't you will blow a 10 ohm resistor every time. I've worked on hundreds of these receivers I know. They need the output circuit soldered at the voltage driver ic's and quite possibly some capicitors replaced on the digital board. The caps mounted near the heat sinks dry up the fastest. These are nice amps. Larry's Electronics Sacramento Ca. ledstiles@hotmail.com
Apr 24, 2010 | Sony STR-V444ES Receiver
Receiver ticks when plugged in... wont turn on. I was using receiver early, very seldom do I turn it off. I turned it off tonight and when I went to power it back on it started ticking... so I unplugged it...
thats the relay that ticks in but is not getting the signal across to the power so have a tech repair your set the problem is in the power supply the regulator is damaged.good luck.
Feb 28, 2010 | Sony STR-V444ES Receiver
Got a humm noise when I turn receiver down,it does it on all functions what is it
Chances are it's the Large Electrolytic Capacitors in the power supply. As you have it on all functions. These are to filter out the 50/60HZ hum in the mains supply and so that's most likely what you are hearing!
Feb 24, 2010 | Sony STR-V444ES Receiver
The remote volume control fails. It can be caused to work again for a short time by manipulating the control. How do I get at the control to replace it. Where can I get a schematic?
you can find a remote replacenment at sony autorizad service center if they dont have it in stock they will order it for you the service manual is hard to get at this time
try this number for parts
1-800-488-SONY (7669) good luck
Dec 19, 2009 | Sony STR-V444ES Receiver
Sony Receiver STR-V444ES and Blueray
You might have to go into the players setup and select the output and audio stream options. If it is set for PCM only it will not receive the Dolby or DTS signals if you selected them in the DVDs audio selection menu. There may also be a signal select in the Sony receiver to assign the digital inputs to selected units.
Hope this helps
Cheers
May 08, 2008 | Sony STR-V444ES Receiver
Sony STR-V444ES Receiver Logo
224 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
