Question about ASUS Eee 4G Notebook
I have an asus eeepc4g. i have windows xp in it. i have already used its webcam before with no problems but right now, the webcam won't work anymore, it's all dark no matter how i adjust brightness, contrast etc. what do i do?
  • 33 Answers
Save yourself some money and don't repair it ,buy an external webcam it's the best thing to do. much less you will sent, than having it repaired. Look around for one.
Posted on Jul 17, 2009
No video camera at asus k52n
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver xp
click start right click on computer select properties device manager scroll to image devices expand right click to update driver software if you dont have the driver you will need to download one here are a few you could try although i could not find one for windows 7
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
free drivers solution for 2000/XP/Vista/7/8
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
hope this helps
Sep 22, 2012 | ASUS K52n-a1 Notebook
How can I rotate my Asus f82q leptop webcam?
Open the WEBcam and go to settings. There is a setting to rotate, mirror the image etc.
Jul 05, 2012 | ASUS Computers & Internet
Hiii!! i have a asus G50vt and i dont have the webcam drivers... where can a download it????
hello, get them from here:
http://support.asus.com/Download.aspx?SLanguage=en&m=G50Vt(BestBuy)&p=3&s=133
chose OS and download it, pls first install chipset driver , if u use windows xp right click on setup -proprites-compatibility-window xp
Sep 23, 2011 | Computers & Internet
How to install webcam in asus Eee pc mini computer
Try enabling Webcam in the BIOS. Windows comes with a default webcam that should work.
To enter BIOS, hit F2 or Delete as the computer is booting up.
Good luck.
Mar 01, 2011 | ASUS Eee PC 1000H Laptop
Hi, after windows 7 installation,my asus k50 laptop webcam is working head down,also I can't find my webcam setting.
Dear sir/Madam...
The Laptop come with the motherboard installation disc.Use that disc to install your webcamera automatically.if that disc will not work properly then try to download the right driver for your webcamera . Keep in mind, drivers are vary by the versions of Windows(xp,Vista,7). So you search in google.
Ex: asus K50 Laptop webcam drivers
ALL THE BEST
By Ganesh A(INDIA)
Dec 04, 2010 | ASUS Computers & Internet
I'm using a intel ICP3 webcam. It use to work on my window xp but now I changed mine to window 7 ultimate and it doesn't seem to work anymore. Before on the window xp the software just found the software...
1st You download Webcam Driver. Intel Cam Driver Windows 7 After this install the Webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 10, 2010 | Intel ICP3 Webcam
I cannot connect to the net by wireless-connects fine with a cable.Am a private user so no admin problems Thanks
Hmm click "start" then "run" then type in "cmd". at the command line type in "ipconfig" Write down the IP address there. It will likely start with 192.168.1.*
* means some number between 1 and 255.
then shut down the computer and unplug the cable and turn on the wireless and let it boot back up. Now do that process listed above again and see what you get. If the numbers match or are really similar then your problems are half solved. If you are using icky Vista then you will need to make sure that that wireless network is set to private. You will also need to see what wireless networks are available and connect to the strongest one.
Mar 09, 2010 | ASUS Eee 4G Notebook
Webcam for ASUS K40IJ Series
If your webcam image rotated, install the driver.
I also experienced webcam's issue. http://www.ryan-isra.net/asus-k40ij-webcam-rotate-windows7
Oct 26, 2009 | Computers & Internet
How do i get webcam to work on my asus Eeepc4G
click the webcam on in the utility tray icon (lower right bar on bottom of screen).
May 14, 2009 | ASUS Eee PC 4G Surf
Webcam driver
Some times BIOS disable webcam after updating it.
To enable it do the followings:
1. Restart your Eee PC.
2. Press F2 while booting (to enter BIOS sittings)
3. Go to "advanced" tab (by pressing right arrow)
4. Select "Onboard Device Configuration" (by pressing down arrow)
5. From there you can find if "Onboard Camera" is enabled or not.
6. If not, just press enter to pick "Enabled"
I hope that would help :-)
Apr 23, 2008 | ASUS Eee 4G Notebook
ASUS Eee 4G Notebook Logo
145 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
