Question about IBM ThinkPad 600E 2645 Notebook
Getting message 8611 failing to start
Ibmthinkpad600e........on startup get failure message8611
  • joe joe Apr 10, 2009
    when i start up my computer a pop up window shows up and says error 8611 then i restart but it still cat work and i dont know what to do.
  • 127 Answers
The 8611 error is telling you that the trackpoint or keyboard for the Thinkpad has stopped working
You can sometimes get the 8611 error:
  • If an emergency power down is made by switching the system off during or while an application is open, then immediately switching the system on creates a 8611 error.
  • Repeatedly turning power off and back on without properly shutting down or allowing the system to shut itself down.
The Solution:
  • Wait at least 6 seconds or longer after shutting down the system or before restarting to correct the 8611 error
If the above doesn't work you will have to disable the Track Point:
I did the following procedure from information I found on the Internet, and it worked, only you will need to use a mouse with the laptop from that point on, you are basically turning off the trackpoint which is causing the error.
There is no guarantee this will work because it may also be the keyboard itself, so do at your own risk.
First go into the system config utility which you get forced into after the 8611 error is reported
Then go back to the main menu and enter the config.
When there press the control key and the d key at the same time..
Find and ensure you are on the -base 128 cmos- page.
Look for ofset 20h, (maybe a different number ##h) and in the1st column and 3rd row and change the number to 01. On my Thinkpad the ofset was not 20h but 12h., so my ofset number wasn't the same but it is still 1st column, 3rd row.
When finished changing the number to 01 press the F2 key and then the F3 key.
Then exit out and restart the computer.
The computer should reboot with the trackpoint disabled. And you will need to use a mouse with the Thinkpad.
Posted on Mar 15, 2009
Thinkpad T60 starts up with a POST error of 8611
Turn the ThinkPad on. It gets the error 8611,
and you get a popup to TEST or RESTART.
- Type RETURN to Test -- this gets you to a screeen full of System Tests.
- Get out of the Test Screen, by typing ESC,
this gets you to the main BIOS 'Easy Setup' page.
- Choose 'Config', it comes up with: Memory; SystemBoard; Display, etc.
- Type: CTRL-D (undocumented!) -- this gets you into
the 'System Configuration Edit Utility', which allows you
to edit the BIOS BootCode in the CMOS (hack!).
- Change the value at Offset 20h from: 00, to: 01.
- Type F2 to Save, and then F3 to Exit the Hex Editor,
then type: ESC to get back to the 'Easy-Setup' page,
and select: Restart (hit Enter in response to OK?).
- It should now reboot, and bypass the 8611 error.
Apr 19, 2010 | IBM ThinkPad T60 Notebook
Message saying media test failure, exiting pXE ROM and operating system not found. Cannot get anywhere thereafter. can get into F12 and F2 at startup,
Sounds like your hard drive died. If hard drive is dead you wont be able to get into anything but the bios. Hold down the CTRL key when computer starts and dont let go and try to force it into going into bios for you.
Mar 04, 2010 | Dell Inspiron Mini 10 Notebook
Nokia 6600 startup failure
I have the 6600, last week the mobile couldnt work. phone registration failed contact retailer message displays. i have many messages in that mobile. i contacted the retailer, but the retailer told only solution is flashing the mobile. shall i get back my messages in that mobiles please help me
Jan 05, 2010 | Nokia 6600
Armada m700 working fine. oneday got message 1782 disk controller failure. have tried removing things. will get message even if hard drive & caddy removed. have reset startup sequence have tried with...
 disk controller failure - the chip from the laptop's motherboard that's controlling the disks is fried. Nothing you can do - all hd's will be unrecognized - that laptop is dead.
 Buy a new one.
Oct 30, 2009 | Compaq Armada M700 Notebook
Need to formatting nokia 6260 mobile
Hello sir,
I got the same startup failed problem. Did u get any solution. Please let me know how to resolve this issue. my id is surenar.malreddy@gmail.com
Thanks.
Mar 23, 2009 | Nokia 6260 Cellular Phone
Thinkpad x60 reboot fails. Error message: Media test failure
plz check the hard disk data cable(cable which is connected to motherboard), if changing the cable do not solve the problem your hard disk may be corrupt
Mar 01, 2009 | IBM ThinkPad X60 Tablet PC
Message appears at startup
I sugges you to download an Autoruns program it will help you to remove unneeded startup items.
Good luck
Feb 20, 2009 | 3Com Home Connect Lite Webcam
When i try to start my computer i get the message windows failed to start and i get the two options to run startup repair or start windows normally. startup fails to fix the problem automatically. i then...
If you have the CD's that came with your notebook, there should be a recovery disk. Insert that disk and see if it solves the problem. If not, than I suggest you reinstall Windows and start from scratch.
Dec 31, 2008 | Acer Aspire 5100 Notebook
Windows fails to start and startup repair does not work.
Your startup repair option in Windows Install indicates a hardware conflict. Go to your System Setup in startup mode, by pressing Del, F2 or F10 whichever the hint is on screen during bootup. Once inside system setup, turn off almost everything, disable Speed Stepping in EPower, set monitor off to disable, Standby and Hibernation off as well. Turn off the modem and Network adapter if yo can. Just about everything that affects a device on the laptop. This would also include the Touch Pad if you're using a mouse.
And, in the long run, you may need to do a full Windows Install if the repair option continues to fail. Many of these failures are due to the Virtual Memory file size for Drive C being too low. If you can get into Safe Mode change this setting, right click My Computer, select Properties, go to Advanced, advance and change Virtual Memory on C to a fixed size about 1024Meg for min and max.
Also, should you be low on free space for drive C this could cause the same problem. You would have to choose a Full Install as an Option unfortunately.
In the absence of anything along these lines working, you should be able to choose Restore Acer option (or words to this affect), you would want to tap on F8 while booting, sometimes its F10, but this gives you a 'boot from what source' option, CDROM, Hard Drive or Restore Partition. Choose the Restore Partition and start over from scratch again.
Sorry, but this often happens and you and I have to live with this.
If you need any clarifications on what I've just stated, use the Comment Box Text Entry box below to send me a message. I'll get an email alert and will get back to you as soon as I can.
Regards,
Worldvet
Nov 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
311 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
