Question about Sewing Machines
Setting tension for babylock tiara
I have loops on the top of my garment when quilting
bargainbox
  • 1388 Answers
SOURCE: how do I know which tension to adjust?
Are you sure that a stitch is being created each time, or is it missing some....
On a scrap, sew a zigzag to ensure that at least the stitches are being formed, if not, or missing some, look to timing.
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
bargainbox
  • 1388 Answers
SOURCE: top tension is making a loop as I sew, bottom
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 19, 2009
chrismyers67
  • 53 Answers
SOURCE: Pfaff Select 4.0 has looping on bottom of fabric, free motion qui
Make sure your are lowering the pressure foot first before you start sewing. With the free motion foot, you still have to lower the pressure foot, this allows tension to be put on the top thread and allows the foot to work properly (when the needle goes down so should the foot and when the needle comes up it should lift the foot up.)
Also make sure your tensions are in a middle setting and that you are threading the machine with the pressure foot up.
The way to insure you will not get your problem is with the foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
hope that helps :)
chris
Posted on Jun 06, 2010
SOURCE: tension settings for the babylock sewing machine
My babylock 1556 bobbin thread is too loose when sewing, how do I get that tightened up?
Posted on Mar 15, 2011
SOURCE: Just bought a brand new Pfaff Quilt Expression 4.0
this is a known issue with the pfaff.....i have just bought the machine and it has thread uptake issues...thread tension issues and it comes unthreaded by itself often...leaving globs of thread on the bottom stuck in the feed dogs and under the throat plate.....then the stitches are not properly balanced because the tension gets too loose on the bobbin thread....very disappointed to find out it is a known issue with all the viking husqvarna made machines...which are pfaff, janome and viking.....sux.
Posted on Apr 01, 2011
Underneath of quilt the stitches are long with smaller topstitches is my top tension to loose or too tight
YOur top thread is looping, right? Re-thread your top thread, making sure you floss it into the tension system. When you drop the pressed foot it should offer tension to the thread. Right? When you have underside loops it would indicate too much thread, right? So either the tension is too low OR something is jerking on the top thread causing a loop.
Nov 20, 2013 | Baby Lock Esante
LOOPS WHEN SEWING
This is a top tension issue, you need to check two things,
-make sure you thread the machine with the pressure foot up ( this allows the tension discs to open up so you can pull the fabric away from the machine with the foot up and allows the thread to get to bottom of the tension discs)
-make sure your tension settings are set to the medium setting. (Usually 4 or 5)
If this still does not help, then turn the top tension knob up (from 5 to 6,7,8,9....)
-If that still doesn't do it, your probably need the tensions reset, and your local family sewing store will be able to assist you further.
-Chris
Jun 06, 2010 | PfaFF Quilt & Craft Pro 7530
When free motion quilting the bobbin thread loops and snarls. The machine is not currently on a frame, but I have a Grace Sturdy Light and want to put the machine in (the quilt is rolled and ready), but I...
Try threading the machine with the presser foot up and see if the loops and snarls go away.........
When the foot is down during the threading, the tension control is closed and the thread cannot enter as it should.
No tension control of the top thread and the bobbin thread cannot connect for a proper stitch.
Mar 12, 2010 | Janome 1600P-DB Mechanical Sewing Machine
Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Mar 10, 2010 | PfaFF Quilt & Craft Pro 7530
My machine is skipping stitches when I free hand quilt & the top thread is looping on both the top & the bottom
Make sure you have your thread through all of the thread guides, If I feel I need a little extra tension I loop my thread through the bobbin tension guide on top of the machine, especially if it is a fine or silky thread for decorative work. Make sure your bobbins are wound tight and also threaded correctly. When freehand quilting you should sew at a moderate speed and make sure to move your fabric smoothly with the speed at which you are sewing, you may just have to practice a bit like I did...If none of this works you may need to take your machine in and have the tension set on the bobbin housing itself..
Oct 26, 2009 | Singer 7436 - INGENUITY
Tension and missed stitches
It sounds like one of your clearances in the machine is off. When a machine skips stitches like yours is doing, it does so because the hook responsible for "catching" the thread from the needle is not close enough to the needle so it misses the loop of thread from the needle. If your machine was having a timing problem it wouldn't sew well on any fabric. A clearance problem shows up on certain fabrics at certain times. A few things you could do to try to compensate it would be to use a slightly larger needle and turn your top tension dial down to a lower setting. Move the machine a little slower on the frame or increase the speed of the machine. Either way a trip to your technician will be needed. Make sure you tell him to check the needle to hook clearance.
Sep 19, 2009 | Husqvarna Freesia 425
Tons of loops of thread on back
Make sure that, with the darning foot installed, that you LOWER the presser foot lever. It won't look like it went down, but the lever must be down for the tension to engage.
Set the upper thread tension to 7 or wherever it needs to be right. Don't be afraid to change the numbers, they are there for reference.
Jul 11, 2009 | Baby Lock Eclipse Serger
Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Tension issue
If you set the tension from 3of 4 to 1 you actually lowered the tension. To increase the tension you must set the tension to 6 or higher. Be carefull not the set the bobbin case tension to tight as this will also have negative results
If suggest the following: First lower the bobbin case tension, half a turn. Then increase the top tension to 6 and see if there is any difference.
If you do this systematically you should rectify your problem.
Good Luck
Jan 21, 2008 | Kenmore 12102
Sewing Machines Logo
390 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
