Question about RCA Rc40 Clock Radio
RC142: how do I turn off the alarm for a weekend?
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
Why is my alarm always onn
Alarms are designed to reset every day after you stop them so they'll wake you the next day without you having to do anything. Look for a setting on your clock radio that lets you turn the alarm completely off. You'll be able to tell when you've succeeded, because the indicator on the front panel that shows whether an alarm has been set will disappear. Don't forget to reverse the procedure and turn the alarm on when you want to awakened the next day.
Oct 08, 2014 | Audio Players & Recorders
I have the emerson smartset clock radio. model cks1702. i need the mannuel so i can set it to go off through the week
There are several SmartSet clock Radios by Emerson. Which model do you have?
It's possible that you have alarm 1 and alarm 2 both set for weekends (if a two-alarm version). For the SmartSet radio, CKD5811, that I am used to, you can change the alarm mode between Everyday, Weekdays and Weekends. Press and hold the Alarm 1 (or Alarm 2) button then press the Alarm Mode button to toggle between the modes. Then release both buttons. If you press the Alarm 1 button, you will see the current alarm mode indicated by the indicators by the day that are lit. The Alarm Mode button is between the On/Off button and the Alarm 1 and 2 buttons on the CKD5811. Make sure that you have the Wake to Radio, Wake to Buzzer or Wake to CD slide set for the alarm in question. For Wake to Radio, set your station. For Wake to CD, make sure that the CD in the unit is one that actually plays in the unit (scratches, etc). Also check the volume (although that seems like less of a concern since it does wake you on weekends).
The manual for the CKD5811 is here:
http://www.emersonradio.com/resources/owner_manuals/manual_1312917117.pdf . Additional manuals are here: http://www.emersonradio.com/owner_manuals.php . Scroll down in the drop down menu for the SmartSet manuals (clock radios all start CKD). The manuals are in alphabetical order.
I hope this helps.
Oct 29, 2011 | Emerson Smartset Clock Radio
How do I turn off "Weekend Skip" on the alarm set?
Normal 0 0 1 48 278 2 1 341 11.1287 0 0 0
To turn the ‘weekend cancel’ feature off you must press and hold the ‘weekend cancel’ button for about three seconds. Afterwards, the ‘weekend cancel’ display will start to flash. When it stops flashing (about three seconds later) release the button. To turn the feature back on, simply press the ‘weekend cancel’ button once again.
AndrewG
Jan 17, 2010 | GE 7-4894 Clock Radio
Turn alarm off for weekends???
If its anything like the RCA model I have, you have to simultaneously hit the alarm button for the alarm you want to turn off AND the off button, so both at the same time.
Oct 26, 2008 | RCA RP5420 Clock Radio
Alarm on weekends
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Sep 01, 2008 | Timex T625T Clock Radio
Weekend alarm cancel function
hit the cancel button then the wake1 or wake2 button as you need to cancel them.
Oct 28, 2007 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
RCA Rc40 Clock Radio Logo
26 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
