Question about Dell Computers & Internet
Loanding pbr for descriptor 2 done
  • 15 Answers
Hi there.. i'd really hate to say it but you have to reinstall your operating system.. honestly even if your're gonna try running chkdsk/p or /r it still no good it will just waste your time.
Posted on Mar 12, 2009
What does it I mean when it says loading PBR for. Descriptor 2 failed?
That message indicates that the Dell backup partition is trying to load but can't. I would suggest that this indicates a hard drive failure. You can try pressing ctrl+F11 during the startup to try to access the system restore partition, but it looks like, to me, the hard drive is toast.
Jul 17, 2014 | Computers & Internet
Loading pbr for descriptor 2 done. cant go eatherway backwards or forwards
try this do a total recovery or factory reset from windows recoverypartition.to get there tap on F8,F10 OR DEL.then there use the use tools there to recovery.do this when windows boot one tap a second.
Apr 08, 2013 | Dell Computers & Internet
My Dell says loading pbr descriptor
1)Try F8 safe mode and follow directions.
2) Insert installation disk and use repair option.
Apr 04, 2012 | Dell Computers & Internet
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
I have a inspiron i1011-26600bk and its telling me a message that says Loading PBR for descriptor 2...done. What should I do?
"Loading PBR for descriptor 2 ... failed" would be the exact error message if the MBR is unable to load the partition boot record for the second partition. There may be more, but here are three possible causes:
1) the partition table is corrupted so that the descriptor points to the wrong place (i.e., says the partition is one place when it's really somewhere else);
2) the partition table descriptor points to the right place, but the boot record there is corrupted or has been erased;
3) The hard disk is failing and having trouble reading the sector with the boot record.
To check (1), visit www.goodells.net/dellrestore/fixes.htm and download the dsrfix utility. In short, if dsrfix reports a clean bill of health, then (1) isn't the problem.
To check (3), run hard disk diagnostic tests. Press F12 when the machine is starting and see if the bios boot menu offers you a hard disk diagnostic test that you can run. Or even better, if you know the brand of the hard disk, most manufacturers should have a free diagnostic utility you can download to test the hard disk.
If it's not (1) or (3), then use Ctrl+F11 to run the Dell restore utility to recreate the Windows partition.
Mar 12, 2011 | Computers & Internet
A disk read error occurred press ctl+alt+delete to restart
May I know whether the Hard Drive is listed in the BIOS? Try reinstalling the Windows using the Windows OS disc.
Jul 04, 2010 | Dell Inspiron B130 Notebook
Loading PBR for descriptor 2... MODEL DELL DV051
That is the boot loader message to boot to the NTFS Primary boot partition (Primary Boot Record for Descriptor 1 is the Utility partition)
Normally, this message flashes and the system boots, since it is not there is a failure in the boot process.
#1 run diags on the Hard Drive (CTRL+ALT+D at boot) and see if it passes
If it does
#2 Boot to you XP CD, press R for recovery console, and run the COMMAND CHKDSK /R see if the system will boot
If no go, go back to recovery console, try the command BOOTCFG /Rebuild then see if the system will boot
If That fails, try reinstalling Windows
If Diags Fail or all the above fail, replace the hard drive
Jun 24, 2010 | Dell Computers & Internet
Start up gets to "Loading PBR for descriptor 2... done"
I suspect that the viruses had infected some of the files that windows needed to boot up. The moment you ran the Mcafee, the scanning might have deleted or quarantined those files. That is the reason you're having this Loading PBR message because it is now trying to boot from the network and not from the hard drive. You will need to repair windows using the CDs that came with the computer (the Operating system CD/DVD) and run CHKDSK /R at the screen where it says 'repair your computer using the command prompt". If this does not work, chances are, you may need to reinstall windows and everything and that all information in your hard drive will be wiped out.
Jan 03, 2010 | Computers & Internet
When I first power up the notebook, it says " loading PBR for descriptor 2...done" pleaseadvise what to do next?
hii
This problem which you are facing is a hardware problem so you can go to vendor or you can visit our senoir technician at----http://tinyurl.com/nznbpm
Jun 20, 2009 | Dell Inspiron 2200 Notebook
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
169 people viewed this question
Alun Cox
