Question about AT&T DECT 6.0 Cordless Phone System with Digital Answering Machine
How do you set time and date on an AT&T CL82101 base?
How do I reset my date & time for Panasonic kxtga470
The KX-TGA470 handset works with several models of Panasonic cordless phone base units. Press Menu and then press #. Next press 1 0 1 . (Alternatively use the arrow keys to navigate to find Initial Settings and then Set date and time after pressing Menu.) If you need to change the date, type in the date as three sets of two digit numbers (month, day and year). Then press OK. Next type in the time. Press OK and then select AM/PM with the arrow keys if you are using 12-hour time. Finally chose Save followed by Off.
The manual for the base describes setting the date and time. See http://panasonic.ca/viewing/ALL/KX-TG4711C/OI/TG4711C_PNQX5094ZA/TG4711C_PNQX5094ZA.pdf on page 15.
I hope this helps.
Nov 03, 2014 | Lands Phones
Can't find how to change the date or time
System
Setting the date and time
To set the date and time, tap
APPS
Settings
Date & time
Tip
: If you travel frequently or live in
an area that uses daylight saving
time, and have mobile network access, activate
Automatic date & time
from this menu. Your tablet will set the date and time based on information
it receives from the network
Mar 11, 2014 | Acer Iconia A1-810
Change time
Press "OK" button.
Scroll down to "Settings", (May be handset settings.)
Go Right on scroll button.
Scroll to "Date & Time settings"
Enter date and time.
Nov 03, 2013 | Panasonic KX TC1881B Cordless Phone...
Set screen date/time in kodak easy share
Hello There!,
I think I can help you :-)
Here is the link for the user manual
http://gdlp01.c-wss.com/gds/7/0300001857/01/PSA480_CUG_EN.pdf
On page 16 it explains two ways to set date & Time.
1st is when you turn on the power it will ask you to set the time & date, and you can enter it.
2nd way to set time & date, or change it is to press the MENU key, and select "Set Date & Time".
I hope this helps you.
Please also giving me a good rating for offering you help, :-)
Thanks,
Sep 17, 2011 | Canon PowerShot A480 Digital Camera
How do change time by one hour say 2.30 to 3.30 7020 phone
Select Menu > Settings > Date and time. To set the date and time, select Date & time settings. To set the formats for date and time, select Date & time format. To set the phone to update the time and date automatically according to the current timezone.
You can get more help from downloading the manual from Nokia at http://nds1.nokia.com/phones/files/guides/Nokia_7020_UG_en.pdf
Mar 13, 2011 | Nokia Cell Phones
HOW DO I SET TIME AND DATE?
The Date & Time have been reset message appears after the Language screen the first time you turn on the camera. It may also appear if the batteries are removed for an extended time.
  1. SET DATE & TIME is highlighted. Press the OK button.
    (Select CANCEL to set the date and time at a later time.)
  2. Go to Step 4 below, Setting the date & time, anytime..
  1. In any mode, press the Menu button.
  2. Press autourg00205001id1456505.jpg to highlight Setup Menu autourg00205001id1561971.jpg, then press the OK button.
  3. Highlight Date & Time, then press the OK button.
  4. Press autourg00205001id1474816.jpg to adjust the date and time. Press autourg00205001id1474821.jpg to advance to the next setting.
  5. When finished, press the OK button.
  6. Press the Menu button to exit.
Aug 27, 2010 | Kodak Cameras
HOW DO I SET THE DATE & TIME ON THE ANSWERING MACHINE DS6221-1
Hi there, I found my manual that states:
Press MENU/SELECT to display menu when in idle mode.
Press the up or down triangles to reach DATE/TIME. Press MENU/SELECT.
Use the keypad to set the year. Press MENU/SELECT.
Use the keypad to set the date. Press MENU/SELECT,
Use the keypad to set the time. Press the up or down triangles to select a.m. or p.m. Press MENU/SELECT
The screen displays STORED and you'll hear a confirmation beep.
George Rocks
Apr 18, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Need to set time & date on the cordless. RCA Model No. H5401RE1-A
From page 14 of the manual: "The time cannot be set manually in the handset, only at the base. Any update to the base time will be automatically sent to the handset."
Apr 08, 2010 | RCA ViSYS 2-Line Speakerphone
Setting time
My Uniden 6.0 Dect, I had to set date & time with the select button on the hand set, which resets the base...
Nov 26, 2009 | Lands Phones
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
attention:
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=18155
Please rate this solution. Thanks.
Oct 15, 2009 | Canon PowerShot A480 Digital Camera
AT&T DECT 6.0 Cordless Phone System with Digital Answering Machine Logo
21 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
