Question about Gateway CX2608 Notebook
Got laptop wet...
What needs to be replaced if it can be fixed at all?
  • Mon Sam Aug 03, 2007
    ok, i tried turning it on for the first time after 1 week of waiting for possible water to dry up. (advice i got from friend) as a result, small white smoke started to appeared and burnt smell occured. fearing i was about to start a fire, i yanked the battery out. (not sure if that was good idea or not) took laptop apart and to no surprise at all found burnt spots all over the motherboard. so my question is now, besides the motherboard and keyboard, do you think that everything else is ok? I hooked up the harddrive to my pc and it works fine amazingly.
    Problem Solver:
  • 6 Answers
All electronics is destroyd by dirty water, or saltwater, any eletronic attched to it, may not be destroyed exept from, if it is directly attached to that component that went defekt, by if the comonent do lead power as higer voltage than it usuaky was ment to supply! Therefor, a harddrive, is NOT directly connected, therefor it may in 99% of the time, not be affected, allso sutch as videocards, soundcards and others! Caus this components draw its voltages directly from the powersuply, not via mainboard!
Posted on Aug 04, 2007
  • Anonymous Aug 07, 2007
    Solution #2 ???
    This is NOT a way to do things,
    as the pc do NOT stand the sun-light,
    it says in this manual, that you should avoying having the pc in direct sunlight as this will destroy the LCD and plastic!
    This pc is in shape that it do only work as spareparts!
Hi In water spilled cased as in u case best method is dry up the laptop in placing in sun light. Mostly your Keyboard , motherboard and memory modules are affectyed in liquid spillage cases. From 5 years expereince in DELL systems
Posted on Aug 03, 2007
  • 65 Answers
If it does not power on the motherboard and the keyboard should be replaced. If it got wet with anything but water it usually has a corrosive action over a period of time so it could be worse. We have seen systems get hit by cola drinks and it ate the circut etchings off the memory modules as well as the motherboard.
6ya staff
SOURCE:
My keyboard i koko when i press o i get + and when i press l i get enter what?
your keyboard needs replaced most likely either it gotten wet or its just worn out.... the only other thing i can think of that you might check is to reinstall the driver for the keyboard --- that might fix the issue
Sep 03, 2014 | Lenovo Computers & Internet
How do you fix a ibm computer after the inside gets wet
if the water has chlorine, there is still a chance laptop can be fixed after all the water was out and laptop was totally dried up.
otherwise you need to buy a new laptop if the water is salty, etc.
May 10, 2012 | IBM Computers>Laptops Lenovo ThinkPad T60...
My netbook keys aren't work, it's been a while since it's gotten wet. What is the best thing to do?
The netbook keypad will need to be replaced in order to fix the problem, I recommend having an inspection done to make sure there no other issues.
Apr 09, 2011 | Computers & Internet
I spilled coffee on the table and the bottom of my laptop got wet. a message flased that windows was shutting the computer down. after removing the battery pack and several days of drying it out the laptop...
Buy a new battery, if it still dosen't work then you jammed your PC, take it for a repair or to the manufactures. wetting a PC/laptop is not what you need.
Oct 17, 2010 | Dell Inspiron 1501 Notebook
Aspire 4720 PC Notebook: sticky keys, some liquid wet the keyboard...
Its hard to get them working again properly, i had to replace 4 sticky keys finally. I found this company who sell laptop keyboard keys at a very good rate, and even have tutorial's on how to fix the keys , that makes it really easy ...
www.laptopkey.com
May 17, 2010 | Acer Aspire 4720 Notebook
7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum: I have a Bissell 7901-1. I need to replace the pum...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
78iiry
May 17, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Keyboard and trackpad got wet
it may work when it dies out...otherwise you will most likely have to take and have the keyboard replaced
Jul 21, 2009 | Apple 13.3 MacBook Intel Core 2 Duo...
Bissell Proheat 2X Wet Vacuum
heatman101
dssdf
Aug 04, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Open Questions:
RR MAIL mail password reset #{18OO~8O31O69} phone number usa asif There are two circumstances that can cause someone to want to change his/her RR MAIL password: 1 forgetting the RR MAIL password and needing to recover it and 2 to change the RR MAIL password. The latter can be because the RR MAIL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's RR MAIL password at least once in a month. Contact RR MAIL Mail Password Reset 1-8OO-8O3-IO69 . For your convenience to contact RR MAIL Mail Password Reset We have provided all possible information of RR MAIL Mail Password Reset. You can contact RR MAIL Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an RR MAIL Password The following steps show in detail how to change an RR MAIL password when the current password is known: Sign into the RR MAIL Mail Account from RR MAIL Do you want to recover/reset your RR MAIL email password? So you'll be do the some steps to recover your RR MAIL password. We'll help you to fix your problem and we'll guiding the some steps to recover your RR MAIL password. Follow and do the below steps to recover your RR MAIL email password- Go to the RR MAIL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your RR MAIL mail message on your Gmail account. RR MAIL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While RR MAIL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, RR MAIL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your RR MAIL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your RR MAIL password.
Oct 23, 2019 | Internet Computers & Internet
INCREDIMAIL mail password reset #{18OO~8O31O69} phone number usa asif There are two circumstances that can cause someone to want to change his/her INCREDIMAIL password: 1 forgetting the INCREDIMAIL password and needing to recover it and 2 to change the INCREDIMAIL password. The latter can be because the INCREDIMAIL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's INCREDIMAIL password at least once in a month. Contact INCREDIMAIL Mail Password Reset 1-8OO-8O3-IO69 . For your convenience to contact INCREDIMAIL Mail Password Reset We have provided all possible information of INCREDIMAIL Mail Password Reset. You can contact INCREDIMAIL Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an INCREDIMAIL Password The following steps show in detail how to change an INCREDIMAIL password when the current password is known: Sign into the INCREDIMAIL Mail Account from INCREDIMAIL Do you want to recover/reset your INCREDIMAIL email password? So you'll be do the some steps to recover your INCREDIMAIL password. We'll help you to fix your problem and we'll guiding the some steps to recover your INCREDIMAIL password. Follow and do the below steps to recover your INCREDIMAIL email password- Go to the INCREDIMAIL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your INCREDIMAIL mail message on your Gmail account. INCREDIMAIL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While INCREDIMAIL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, INCREDIMAIL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your INCREDIMAIL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your INCREDIMAIL password.
See all Gateway CX2608 Notebook Questions
Gateway CX2608 Notebook Logo
158 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
