Question about CyberPower OfficePower 650SL UPS System
CyberPower 650SL beeps and clicks. what is wrong?
Why is my Cyberpower 550 VA surge protector beeping in set s of 3 beeps every few seconds after a power failure in the house?
This is a battery backup power supply as well. The beeps alert you that you need to power down your equipment before the battery fails.
The website is here with Support and Manuals
https://www.cyberpowersystems.com/support
Dec 24, 2015 | CyberPower Computers & Internet
One side of my Cyberpower 525SL stopped working. When i press the red button the green light comes on, but goes off quickly accompanied by a beeping. The TV, dish, and vcr/dvd continues to work. Help...
Hi droger68,
The reason for the issue that you have right now with your Cyberpower 525SL is a bad battery. This means that some of the battery relay's component or relay has failed. You may contact the manufacturer if it's still under warranty. If not you may check this site they do have battery for your machine.
Hope this helps.
Thank you for using FixYa.
May 24, 2011 | CyberPower 525SL (CPS525SL) UPS System
Looking for manual for Cyberpower 825avr
You can find the user manual for yoru Cyberpower CPS825AVR here: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 23, 2011 | CyberPower OfficePower 825AVR UPS System
It is making a beeping sound non stop
I looked for quite a while and I couldn't find anywhere that told me what the beep is... My best guess would be the batteries are bad and need to be replaced.
Use the like below and CyberPower will help you with the problem.
http://www.cyberpowersystems.com/support/online-support/ups.html
I hope this helps you.
John
Feb 14, 2011 | CyberPower (R) CP825AVRLCD Uninterruptible...
Quite awhile ago, one side of the unit went dead. Uesterday, after hearing a couple clicks, the unit will beep a few short beeps, then after a little bit, there will be a few short beeps again. I press the...
sounds like it is failing. When was the last time you tested its capacity? Test it to see how long the battery works. If it doesnt then get a new one or send it back where you got it.
Mar 09, 2010 | CyberPower 525SL (CPS525SL) UPS System
'Battery' outlet dead.
Hi There, Its definately the battery. The batteries can be replaced.
Nov 05, 2008 | CyberPower OfficePower 650SL UPS System
Reseting my surge protector
What is the model of your battery back up? When does it beep? What kind of beeps?
Nov 02, 2008 | CyberPower 575SL (CPS575SL) UPS System
CyberPower OfficePower 650SL UPS System Logo
55 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
