Question about Kenmore Dryers
Kenmore Elite dryer heats but does not dry
I have a Kenmore Elite HE3 dryer. I've tried to dry a load of clothes, but they keep coming out damp. I ran the cycle 3 times and the load of clothes is still damp. When I feel the clothes, they are warm to the touch, so it appears that the heat element is working. So, the dryer has heat but does not dry.
Thanks.
  • 686 Answers
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Posted on Mar 12, 2009
Sounds like the vent is plugged
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
He3 dryer stops after a few minutes I pause it twice reset it and its good to go
I doubt it. The thermister changes in resistance with temp change. The resistance is monitored by the brain. E-1 usually is an eprom error most times. Your tech sheet lists errors and what to try to fix that. It is located in a jacket inside the kick plate where you access the heating element under the drum. You could have some wax buildup on the sensor strips located below the filter inside. The strips are also monitored for resistance changes associated with dampness of clothes. No dampness means no resistance so the brains thank the clothes is dry and shuts off the program. Purty clever I must say. Try cleaning the junk off the sensor strips is what I would do, so that moisture can be monitored easier fer the brains of the outfit.
Jan 22, 2014 | Kenmore HE3 7.0 cu. ft. Super Capacity...
Kenmore elite he3 takes wat to long to dry cloths
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Apr 21, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 dryer stays cold
you probably need a new heater element.
Dec 12, 2008 | Kenmore 82822 Electric Dryer
Not Drying
Had the same issue with my Whirpool. If the clothes are getting hot but not drying then there might be a build up of lint in the exhaust duct and/or passage. Once I replaced the the duct and ran a snake with a brush through the passage (my dryer was on 1st floor, vent ran up to 2nd) and cleaned out the lint build up in filter area it worked like new. Also keep in mind if you use dryer sheets they will leave an invisible residue on your lint filter thus restricting airflow. This can lead to the heating element burning out. The lint filter should periodically be scrubbed with a soft brush (an old toothbrush will do) under warm water with detergent (I use Dawn). This should keep the airflow moving through the dryer instead of keeping it in the drum. Hope this helps.
Oct 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryers Logo
734 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
