Question about Panasonic Sa-pt670 / Sc-pt670 Dvd Home Theater System receiver Only
Won't turn on
I have no power for this item? I have checked the cord and made sure it was plugged in & the outlet as well all is o.k. I unhooked this and plugged in to a separate outlet and still nothing, but I can hear it click? Help?
2 Suggested Answers
tkkjohn
  • 76 Answers
SOURCE: No Power Using AC Power or Battery
I had this same camera. If you have a power fluctuation it can really damage the batteries. make sure it was not exposed to fluctuations
Posted on Jan 26, 2010
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Kracher power washer won't turn on
Sure that the outlet you are using is powered? Is power reaching the motor? - I had my power switch on my karcher break internally rendering machine dead. If power is reaching the motor for sure and it does not run then there has to be an open motor winding. If pump jammed you would hear a humming noise from motor and the breaker would pop.
Aug 26, 2017 | Washing Machines
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
Brothers sewing machine
first check the outlet to see if it works
next check to make sure the power cord is plugged into the machine
correctly.
if you've done the above things, & you push the switch to turn the machine on & it still won't come on, then the machine needs to be
checked.
Sep 05, 2012 | Brother Sewing Machines
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My LG washer won't power up
Double check the cord to make sure all the wires are hooked up to the washer correctly, check your breaker/fuse box to make sure you don't have a tripped breaker or blown fuse, and check the outlet for power by plugging a known working item into it or using a circuit checker.
If the washer is getting power, try holding the power button down(if there is one) for 3-5 seconds.
If that doesn't help, here's a link to LG's customer support options: http://www.lg.com/us/support/contact-customer-service
Feb 09, 2012 | LG Washing Machines
It won 't turn on
check your power cords, check your outlets, check your surge protector, check the switch on the back of the pc. there may be a black toggle switch with a circle and a line, make sure it's flipped to the line side. if all that is normal, unplug the cord from the computer and open up the case. look at all your power plugs and make sure they're all secure, try and reseat the 1 or 2 main plugs, there should be a rectangular 12 pin plug and maybe a 4 pin plug. unplug them and then plug them back in. put the case back together plug it in, and give it a go. if still nothing then you have to troubleshoot whether the power supply is junk or if your motherboard died. we'll move on to that if it comes up. good luck!
Jan 30, 2012 | Gateway 300 X PC Desktop
Panasonic Sa-pt670 / Sc-pt670 Dvd Home Theater System receiver Only Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
