Question about Big Boss 300-Watt Personal Countertop Blender Mixing System
Big boss leaks - Big Boss 300-Watt Personal Countertop Blender Mixing System
Where do we get replacement part cover for Big Boss Juicer ? in Canada
Try calling 1-800-423-4248 ext 233, or here is the Contact Us page for Emson, the distributor of Big Boss products: Contact
May 10, 2016 | Big Boss 700-Watt, 18,000 RPM Juicer,...
I just bought the blender and every time I out something in it it leaks everywhere from this little area. All I missing a part?
It is not going to be leaking from the motor unit you have photographed. It will be leaking from the beaker in the background. Put warm water in it and stand it on the bench to try and see where it is coming from. Sometimes they only leak when the blade is running so sometimes that test will not work.
Apr 07, 2015 | Blenders
Leaking kitchen aid blender
Make sure that the big black nut under the jar is tight. It holds the blade and bearing assembly into the beaker. The odd one can leave the factory not properly tightened up and vibration loosens it off. Nobody is telling you it will be easy to tighten that nut up because it isn't.
Mar 09, 2014 | KitchenAid Kitchen Aid KSB580 5 Speed...
Lost maual
The manual /recipe book can be downloaded for free. Just visit the Home Depot website and look for the Torpedo 10-in-1 page. You can find the 100 plus page manual under the "more info" tab.
Nov 07, 2012 | Big Boss Torpedo Multi-Purpose 10 in 1...
I have asus computer
No the big one is not the blender.
Jun 29, 2012 | KitchenAid Blenders
My new 5 speed blender is leaking help
Check that you have the seal between the collar and glass jar. It looks like the one here. If it missing the jar will leak badly. If this is not missing, please describe where the leak is.
Dec 20, 2010 | KitchenAid KSB560 5 Speed Blender
Back to basics auto serve smoothie machine
Ok here is a number for you too call Tell them your problem and they should have no problem sending you the part you need being that it is new!.....866-290-1851. they are available by phone Monday through Thursday 7:30am until 5pm and Friday 8:30am until 4pm C.S.T. You may need the make and model number (should be on unit!) I think they are a division of west bend inc.
Please rate my response!
Thank YOU!
Jan 15, 2009 | Back to Basics 600 Smoothie Plus Work Top...
Hamilton beach 4200 water dispenser
i have had this unit for 2 years and the first thing that will go out is the cooling fans, they either stop altogether or start making a loud noise. i suggest to anyone else who has this to go to a computer store and buy 2 quality 90mm fans, they will screw and connect right into the unit. mine initally died about 4 months into use and after replacing them with good fans i never had a problem with it. mine however is a dust magnet and if i dont remove the fans and clean off the heatsinks about every 3 months, the water wont get very cold. mine now is starting to leak water, a big loss since we use this thing all the time.
Mar 01, 2008 | Blenders
Big Boss 300-Watt Personal Countertop Blender Mixing System Logo
22 people viewed this question
Top Big Boss Blenders Experts
eyecam
Ross Keen
Are you a Big Boss Blender Expert? Answer questions, earn points and help others
