Question about Yard Machines Garden
Model number for Yard Machine 12.5 HP 38 inch cut
. The model number tag isn't there and the only identification I've found is 1183A-MW. It's also shift-on-the-go
2 Suggested Answers
  • 57 Answers
SOURCE: I have a riding lawnmower yard machine 18.5 hp
If this bracket is just like a heavy wire, it hangs from the right side of the transmission. It just hooks around the top of the housing and spring most likely goes from a bolt in the center of the metal plate at the back of the deck. If this doesn't describe your model, look under the seat for the model # and send a comment back. Lee
Posted on May 19, 2009
Can not find model or serial number
sounds like the machine being from an auction may be STOLEN!!!! since it has no tags, or identification.
Jun 22, 2013 | Garden
GE spacemaker range model number jmp28g0r1wh display goes blank and oven turns off
the model number isn't correct.check and send the model number again.if you changed the sensor this should take care of the f3 error code but the clock shouldn't go blank and oven stops.like i say your model number doesn't show up as a good number,if this machine has a fan in it you could have a bad fan motor,the fan cools off the electronics and if it isn't working the clock assy. can get hot,damage it and it will do this,also i've seen on some models there's a screen where the fan is and dust gets stuck on the screen and the fan can't blow any air,i'm just telling you what i've found before but it sounds like the clock assy. is heating up and shutting down,if there isn't a fan in your model it sounds like you have a bad clock assy.if you send the model number i can look it up for you.
Nov 15, 2011 | Kitchen Ranges
I have a poulvan 16.hp /38 inch/5 speed and i dont know what size or inches for the primary mower belt i need to engage the blades to cut.
What is the model number of the mower as it is listed on the tag with the serial number, may be under the seat? I will look it up for you and tell you what part number that you need to get.
Or, you can take the model number from the tag and go to a local lawn mower repair parts shop and they will look it up the same way that I do and they will get it, probably have it in back room. Not all will have it, in that case if I look it up you can call around and ask them if they have it by asking for it specifically, by part number.
Aug 12, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a riding lawnmower yard machine 18.5 hp w/42 inch cut deck i am having a problem putting the deck back on there is a spring and hanging bracket that i cannot figure out where it goes. the only...
May 19, 2009 | Garden
I need a belt diagram for my lawn mower>
If you don't have the model number, I just found a diagram for mine by Google, by typing in "MTD 46 inch deck diagram" It took me to a Parts Tree site and right to the diagram I needed. There are slight model differences but for years, the 46 inch, three blade deck has been essentially the same.
Apr 26, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
26 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
