Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Duet dryer will not power up
I have a Whirlpool Duet dryer and last night it dried a load of clothes, and when they came to an end, it will no longer power on. The light comes on inside the drum when I open the door. When I press the power button nothing happens. I checked the fuse box. I unplugged it for a couple of minutes. I am not sure what else to do. Can anyone give me any pointers?
  • 7 more comments
  • ashley_round Mar 12, 2009
    I don't know if this helps but it says Duet Sport as far as the name goes.
    Duet Sport Model WED8300 SW0
  • ashley_round Mar 13, 2009
    checked it; and it was fine. I even replaced it. I thought could have been the problem too, since it happened with my old dryer. Like I said before when I open the door the light comes on, but nothing comes on or responds on the frot panel.
  • crazy busy Mar 14, 2009
    model number GEW9250PLO- same exact problem, light inside the drum is on, but control button will not turn dryer on
  • groovykgriff Mar 15, 2009
    my dryer stpped running last night ,the lights still work on the front panel but dryer will not come on.
  • ashley_round Mar 19, 2009
    The thermal fuse is located next to the motor.  You will see a aluminum tube come from the motor and about four or five inches out you will see two wires going into the tube.  Depending on the model it should be the thermal fuse.
  • ashley_round Mar 20, 2009
    I have replaced the thermal fuse and broke down and called a repairman.  The first thing he did was check the thermal fuse as well and then another fuse and told me that it was a bad circuit board and it would be cheaper to buy a new dryer....Frustrating.
  • crazy busy May 11, 2010
    can you tell me how to locate the fuse inside the dryer and exactly how to do it, please thanks
  • James Chandler May 11, 2010
    need model number
  • 686 Answers
Check your thermal fuse if no continuity through it then change it, it acts just like a car fuse. If it blows you can't see it you have to test it with a continuity tester. Go here and see what it looks like www.repairclinic.com/SSPartDetail.aspx?s=t-gew9250-%3d%3di2986&PartID=2986
Posted on Mar 12, 2009
  • 30 Answers
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Posted on Sep 19, 2009
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Posted on Oct 26, 2008
Sea Breeze
  • 4655 Answers
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
Posted on May 22, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have cleaned vents ducting and still have drying problems gets hot but not drying clothes. whirlpool duet front loading dryer. takes 3 to 4 hours to dry.
go to the end of the vent and actually feel if there is air coming out if not you either missed a plugged vent or the blower is not working. deep inside the lint trap is a hard spot to find it plugged als can you hear the drum spinning
Oct 30, 2010 | Whirlpool Dryers
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Mar 15, 2009 | Whirlpool LER5636P Electric Dryer
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer not drying
look at the vent outside and see if it closing or even has a cover this allows cold air inside the dryer and cause it to take longer to dry
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
687 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
