Question about Drills
How to remove chuck from Nu tool CH10 bench drill
  • 1019 Answers
SOURCE: chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Posted on Feb 28, 2008
stug_57u
  • 99 Answers
SOURCE: drill chuck removal
The screw should be left hand thread and the chuck is normal thread. The 'workshop' way to remove the chuck is to remove the screw (done). If the jaws are still working then clamp a sturdy allen key in it and whack it against a workbench to unscrew the chuck. If holding the drill in the normal position you would stand with the workbench to your left and whack it down on that. If the jaws aren't working then you can grip the body in a vice and use large pipe grips or stiltsons on the chuck. Also check to see if the chuck spindle will accept a thin spanner to hold it, as this is a slightly more caring way to brace the spindle. Then you can can hold the spanner in the vice and use the allen key in the chuck and unscrew it that way.
Posted on Oct 25, 2008
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: remove a chuck from a skill drill
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Uncscrew screw CLOCKWISE until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Posted on Jun 25, 2009
SOURCE: removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
Is there a key to get a drill bit out on an older model Makita
yes it's a JACOBS chuck with a special key in a powertools shop you can buy this
information on
http://www.jacobschuck.com
If you have a drill in a chuck and it will not lose then
place the drill itself (not the tool) in a ,bench screw and take a little bench hammer with the point of the hammer against 1or 2 claws of the chuck and a middle heavy nylon hammer then you beat the machine slowly of the drill .
Succes
May 29, 2014 | Makita Drills
How to remove a bent chuck from a Ryobi DP101 bench drill press
look inside the center of the chuck... if the is a bold inside, remove it. then place the short side of a 3/8" allen key into the chuck and tighten the chuck... then smack the allen key from the side with a hammer the same direction as forward rotation...
Oct 25, 2013 | Drills
Changing the chuck of a 6408 makita electric drill
Open the chuck and remove the screw inside the chuck (if fitted) the screw is left hand thread, fit the short end of the largest hex key that will fit into the chuck and tighten the chuck, put the drill into low gear and turn the clutch to the drill position, support the drill on a bench and strike the long end of the hex key with a firm blow (right hand thread) it may be neccessary to strike it more than once
Jan 30, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How do you remove the chuck from a Delta shopmaster 350 bench top drill press?
there is a "drift pin" that came with the tool, you would need to insert it into the slot and tap on it.
Sep 08, 2011 | Delta DP350 Shopmaster 1/3 Horsepower 12...
Need to know when removing a chuck from a drill is it clockwise or counterclockwise?
The retaining screw at the bottom of the chuck ( down inside where you put the drill bit) is reverse thread. the chuck itself is regular thread. Take out the retaining screw, chuck a 3/8 inch allen wrench ( short side) into the chuck just like a drill bit. Lay the drill down on a work bench with the chuck pointing towards you and the allen wrench clear of the table. Hit the allen wrench with a hammer, ( may take a few tries) in a counter clockwise direction. the chuck should unscrew.
Nov 17, 2010 | Milwaukee Tool Drills
Need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
Oct 07, 2009 | Craftsman Drills
Got a broken drill chuck i cant get off (Dewalt)
first remove the chuck retaining screw LH thread, next shift the tool to the drill only position and the low side. Find a bent handle allen wrench and insert the short piece into the chuck and clamp down, place the chuck with the long portion at about a 30 degree so you can strike it counter clockwise, usually a block of wood or work bench will do and then get a hammer and safety glasses and hit it, it might take a couple times but it will come off
Jul 02, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt 14.4 xrp combi drill
remove the chuck retaining screw, shift the tool into the low position and the clutch into the drill only position. Find a bent handle allen wrench about the size of the chuck (bigger the better) insert short end into chuck and tighten. Put the chuck on a work bench with the long end of handle at about a 30 deg angle and hit it with a hammer. It might take a couple times but it will come off. Let me know if you need any more help, and if I have helped you would you please rate my answer accordingly
May 17, 2009 | Dewalt Heavy Duty XRP 1/2" 14.4v cordless...
Hitachi cordless drill, removing chuck
Replacing the chuck on a drill is simple when you know the trick. I worked at a tool rental center while attending college and learned how to repair many tools. Open the chuck enough to remove the screw that you will see inside the chuck. It will most likely be reverse thread. The chuck is threaded on the shaft so just simply close the chuck on an allen socket and impact off with air or electric impact tool. If you do not have an impact tool close the chuck on-to the largest allen wrench that will fit into the chuck.(with the long part of the allen wrench projecting out) You will need to set the drill into a vise or strap to work-bench, then strike allen with hammer. Most chucks are removed with one quick impact of the hammer, counter clockwise. Do not squeese the drill too tightly with vise, we used a piece of leather to protect the drill. Good luck. Enjoy
Dec 16, 2008 | Hitachi NV45AB2S Coil Roofing Nailer
Drills Logo
524 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
