Question about Baby Gear
I NEED INSTRUCTIONS OR A PICTURE OF A AMERICAN SIGNATURE MODEL # VC900/VC905-57.
I need help on how to fix my old signature 2000 model number JSJ12660 tv with no picture.
projection tvs cost more to fix than they are worth,find a cheap hdtv flatscreen on craigslist or something
May 23, 2015 | Televison & Video
Need user manual
If the installation instructions is what you need you can get a PDF of that on Menards.com Type the pmfw432r8 in their search and scroll down to below the description info and you'll see links to a product spec sheet and installation sheet.
Feb 19, 2014 | Computers & Internet
I need instructions on how I can sign an email document that requires my usual signature via an email attachment on the computer screen. doe's it need scanning first i'm not sure how to go ab
Of course, you need to print and scan:-
1-Print the attached document !
2-Write your usual signature on the printed paper
3-Scan the paper by any scanner
Mar 18, 2012 | Computers & Internet
How can I remove wand to replace hose on Delta signature series 470 model. Can't "unscrew" wand from old hose.
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
Feb 10, 2011 | Delta Model 470: Signature Kitchen...
I want to remove the signature picture from my msn email
try go to this link it may help you
http://help.mymailsignature.com/troubleshooting.html
Troubleshooting FAQs
IMPORTANT NOTE TO AOL, MSN, COMPUSERVE AND SBC ISP USERS:
If you are using the built-in browser provided by your ISP, you will NOT see My Mail Signature or your toolbar. They do not work with the built-in browser. Instead, you MUST:
1) Launch Internet Explorer 5.01 or above from your desktop. (Don't have it? Download here.)
2) Find your browser toolbar - it will have either a "My Web Search" or "My Way Search" logo.
To use My Mail Signature in email: My Mail Signature works with Outlook, Outlook Express, AOL Mail 9.0, IncrediMail (using IE 5.5 or above), and with most web-based email platforms (using IE 5.01 or above), including the rich-text Editor version of MSN Hotmail. (To learn more, click here.)
Back to top
How do I know if my version of My Mail Signature is compatible with Outlook or Outlook Express?
To check that My Mail Signature is compatible with your Outlook or Outlook Express email platform, you will need to do the following:
1) Open a new browser (Internet Explorer 5.01 and above only).
2) Locate your browser toolbar - it will have either a "My Web Search" or "My Way Search" logo - and click the down arrow to the immediate right of the My Web Search/My Way Search logo (far left side of the toolbar).
3) Select "My Web Search Version" or "My Way Search Version". A small window should appear with the version of your toolbar. Check that it says Version: 1, 1, 1, 0 or higher. (Click here to see a picture)
You can also check by opening a Compose/New Mail screen using your email system. My Mail Signature is compatible if you see the navigation bar (with My Signature button) in the Compose/New Mail screen. If you don't see it, first close your email system, open it again, and check for the navigation bar.
Here's what to look for:
Outlook - (Click here to see a picture)
Outlook Express - (Click here to see a picture)
Back to top
How do I know if my version of My Mail Signature is compatible with AOL Mail 9.0 or IncrediMail?
If you downloaded My Mail Signature on or after 3/11/04, it will be compatible with both IncrediMail and AOL Mail 9.0. (Note: You must be using IE 5.5 or above.)
If you downloaded My Mail Signature prior to 3/11/04, you will likely need to upgrade to the latest version of My Mail Signature. (It's free.)
Here's an example of what to look for - (Click here to see a picture)
Back to top
I use Norton Internet Security, Zone Alarm, or similar firewall/proxy software and am having trouble downloading My Mail Signature. Why?
The most common problem when downloading or installing My Mail Signature occurs when running such software. If you are running one of these types of products, try temporarily disabling it, then go back to http://www.mymailsignature.com to try the download process again. You can reactivate your firewall/proxy software once the download and installation of the toolbar and My Mail Signature is complete.
Back to top
I try to download My Mail Signature and the download won't start, or I get looped back to the previous page when I click on Download Now. Why?
The most common problem when downloading or installing My Mail Signature occurs when running software such as Norton Internet Security, Zone Alarm, or other firewalls/proxy software.
Back to top
Why can't I see My Mail Signature - or the toolbar - on my browser?
If you have downloaded My Mail Signature and are not seeing the My Signature button or the toolbar on your browser, you may need to enable the toolbar through your browser's menu. To do this:
1) Click on the "View" menu option.
2) Select "Toolbars".
3) You will see either "My Web Search" or "My Way Search" listed in the dropdown - make sure that there is a check mark next to it. If there is no check mark, click on the toolbar name in order to enable it.
If the toolbar DOES have a check mark but is not visible on your browser, clear the check mark by clicking on the name of the toolbar. Then repeat the steps above to re-enable it. The toolbar should now appear.
Jul 09, 2009 | Microsoft MSN Messenger Connect Service
I cant figure out how to put a signature on my text messages...wen i click on the mms and type in my signature it just does not show up...
The phone only has a signature for multimedia messages(picture messages). There is no way to have a text message signature.
Jul 01, 2009 | Motorola Mobility RAZR V3
Paste picture or drawing to personalized signature in outgoing ma
If the picture is on the internet and has an URL, you can add it to your signature. I don't think you can add a picture from your files. Please let me know if you have a picture on the internet, we can link that to your e mail.
Feb 27, 2009 | Microsoft MSN Messenger Connect Service
Baby Gear Logo
60 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
