Question about Konica Minolta bizhub Office Equipment & Supplies
C4002 en bizhub 282
HELLO TO EVERY ONE Y HAVE THIS ERROR IN BIZHUB 282, I CHANGE DE PH UNIT, POWER SUPLY, MANY THANKS FOR THE HELP
SOURCE: bizhub c250 error code
There are 4 things to try to reset any error codes on these machines
1.) open and close front door
if that fails go to number 2
2.) open front door and turn off main power switch and then turn back on and close front door.
if that fails go to number 3
3.) turn machine off and then turn back on while holding down the utility/counter button after a while a trouble reset box will appear on the screen press on the box and then restart the machine.
If this fails go to number 4
4.) failing all this call your local service agent.
Posted on Mar 10, 2008
xeerie
  • 347 Answers
SOURCE: I have konica minolta bizhub
Replace its imaging unit and developer tank.your machine will start working.
Posted on Mar 25, 2011
  • 51 Answers
SOURCE: konica minolta bizhub
whot is the error code and whot model of bizhub u have???
Posted on Aug 30, 2009
hamzaskilltd
  • 316 Answers
SOURCE: codigo de error E 703 en sharp arm 550
LSU trouble
Posted on Jun 12, 2010
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Solution to bizhub 210 error code c1300
Problem
Polygon Motor malfunction
-Startup failure
- Lock signal fault: Unstable after the first Lock signal has been detected
- Lock signal fault: Lock signal out-of-timing
Solution
1 Turn OFF and ON the Power Switch. 2 Check for proper connection between the PH Unit and Master Board and correct as necessary. 3 Change the PH Unit. 4 Change PWB-A.
Aug 15, 2017 | Konica Minolta Office Equipment & Supplies
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
What does the p14 error message mean on a develop 550
DO you mean C550 Copier/Printer? P-14 means
problems with the following
1. PH relay board (REYB/PH)
2. Printer control board (PRCB)
3. PH unit
4. Imaging unit
Recommend you get a tech out to look at this problems
Print head (PH) contains the LASER. Printer Control Board $$$$$$$$$$$$$$$. PH/ REYB?PH board ALSO $$$$$$$$$. Again have tech come out look at this machine.
May 13, 2014 | Konica Minolta bizhub C351 All-In-One...
Bizhub 282 E73000 error code
CAUSE: With Gmail, the MFP must support SMTP over SSL/TLS. The bizhub 200/250/350 and bizhub 222/282/362 series do not support this functionality.
SOLUTION: An E-mail server that does not require support for SMTP over SSL/TLS would have to be used.
Hope this helps you
Dec 11, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error code p21
This is a color registration error. You can try cleaning the PH units and registration sensors but this model had a TSB about PH unit failures. New PH units were shipped to dealers for every machine they had in the fleet for field repair. If your copier didn't get the new PH units during the "recall" period you will have to pay for them. They must be replaced as a set and you are looking at thousands of $ to repair.
Aug 03, 2013 | Konica Minolta Bizhub c203 Copier
BizHub 353 error code C-4152
Polygon motor rotation trouble
-Check the connector for proper connection and correct as necessary.
-Change PH unit.
-Change REYB/PH.
-Change PRCB
Feb 13, 2013 | Office Equipment & Supplies
How can I solve the problem in Konica Minolta Bizhub 282 error code C4101
You have Print Head Failure, the Print Head houses the LASER along with the LASER is a motor, your code deals with the motor, Motor can not be replaced, entire unit is, try this site they mite have it or will have to get a Konica Minolta Dealer, Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 23, 2013 | Genuine Konica Minolta Genuine Bizhub...
What is error p-21 of konica minolta bizhub c250?
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Apr 04, 2011 | DISH Network IR Remote Control
222 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
