Question about Fujitsu Computers & Internet
Cmos battery drains on Fujitsu Pi 3560
I have changed the cmos battery but it still drains and I have to re set the time each time I switch on the PC
SOURCE: SONY VAIO CMOS BATTERY LOCATION
Correction...
The CMOS battery is located under the system board, and is not accessible from under the keyboard.
The keyboard has to be removed in order to change the CMOS batter, (another reason why I don't like Sony laptops.)
Posted on Mar 27, 2008
SOURCE: nx 5000 looses time everytime i start does it have cmos battery?
yes it has c-mos batter for that you have to change that and for that you download manual from hp website
Posted on Sep 28, 2008
cropp
  • 377 Answers
SOURCE: how to replace cmos battery
hi dear
try this site
http://repair4laptop.org/disassembly_fujitsu.html
thx
cropp
Posted on Apr 12, 2009
  • 76 Answers
SOURCE: how can i locate and change my cmos battery for
The above post sounds simple it is Not, the COMS battery in a Fujitsu V2010 is located just to the left side of the left hand mouse button,( just about where it says AMILO Pro) (under the top cover)
(All power off battery out)
To get at it you remove all the base cover screws including the four on the back edge.
Turn the laptop over and remove the power buttons plastic strip by levering upwards between the gaps that are to the left of the Num Lock key and the right of the Esc key, (use a very thin screwdriver) or slide a screwdriver between the Num lock key and cover leaver upwards, then do the same at the Esc key side, the four retaining lugs are left and right of the cover.
The screen should be laid flat as you do this or you will rip off the keys.
Unscrew the wrap over bracket (right of screen) that holds down a thin black cable.
Pull upwards (carefully) the three connectors in the two recesses below it. (Two in left recess one in right recess)
The cables in the right recess are held down with a strip of black tape remove it and remove the cable from the retaining lugs.
Remove the keyboard screw and push slightly towards the screen to get at the retaining strap and remove the strap by levering the lugs upwards on both sides, put the keyboard to one side.
The wireless card cable is slotted in a channel lift it out. Then unclip and lift out the card still attached to the cable.
Remove the left and right screen screws and carefully lift upwards and remove the screen with the wireless card still attached, put the screen to one side,
Remove the four RAM cover screws and lift off the cover put to one side.
There are 3 tiny screws at the back that are just under the screen location remove them, the last screw is just under the key board in a deep recess remove it.
Finally lift the top cover up slightly and push slightly towards the screens location as the COMS battery is attached to the mother board at front left. (Unplug it)
Work very carefully making sure you do not miss any screws, if it will not come off you have missed something. CHECK.
The cover should come off without any resistance.
The screws are different sizes apart from the base cover screws,( TIP) tape a wide strip of cello tape sticky side up on your work bench and group the screws on it marking with felt tip where the were located.
The wires on the battery are RED and BLACK
Leaver out the battery it’s held firmly by a sticky pad and change it (the wires come attached to the new battery. (Battery VARTA CR2032 3v 0405)
I am writing this from memory but I don’t think I have missed anything, remember if it will not move do not force it LOOK. (Something’s can be done not exactly in the order I have tried to explain it)
Replacement is the reverse of removal.
One site I was looking at wanted £45 for changing a keyboard, that’s a real rip off.
Hope this helps if in doubt take it to a shop.
Best of luck. teastheword find me on E Bay.
Posted on Feb 11, 2010
  • 297 Answers
SOURCE: My Asus Eee PC 1005HAB looses date and time even
hi shubhanan,
You can't set it in the CMOS Settings?Try setting if first then exit and saved..then enter again to CMOS and see it still unchanged.Try another battery.
mastergani
Posted on Jan 21, 2011
Repair manual for fujitsu amilo pi 3560 pc laptop
Computer repair manuals are not available for several reasons, including that components may change and that manufacturers do not want the liability involved in unskilled people working with electronics. As it is several years old it is out of warranty, so first Google amilo pi 3560 technical specifications to discover what you can about exact components. Then Google the repair procedure you wish to perform, along with the make/model, for example replace hard drive amilo pi 3560.
May 08, 2016 | Fujitsu Computers & Internet
Where can you find the CMOS battery for Fujitsu Siemens Amilo PI3625
On the web!
Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie - YouTube
? 6:39
www.youtube.com/watch?v=s8kKHChQ2sw
Oct 16, 2013 - Uploaded by MrHarsel Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie ... Fujitsu-Siemens Amilo Pa 3553 - Disassembly and fan cleaning - Duration: 16:09. by ...
Sep 25, 2015 | Fujitsu Computers & Internet
How do I fix my CMOS Battery Low error so I can correct the Time and Date since it's stuck on the 01/01/2004 date and won't save in my BIOS?
This is usually a very short and sweet step to complete.
After you have changed the CMOS battery over to a new one all you should have to do is go into BIOS set the date, the time and the year. Save the settings in the BIOS, exit and restart the computer.
You have to set the date, time and year in the BIOS first then change it on the desktop.
The proper battery to use for CMOS is a C2023 coin cell battery.
Hope this helps
Jan 12, 2015 | Lenovo 3000 J205 9686-A12 Desktop Pc -...
Cmos jumper location fujitsu amilo pi 3540
Yep, no jumpers. This isn't a desktop computer motherboard.
You can try to remove the RTC Battery.
(Real Time Clock battery. Also known as CMOS battery)
Problem is with this age of laptop there is a Capacitor, or capacitors, that hold a residual charge. Enough to keep a BIOS password FOREVER.
Usual method would be to jump across two tiny pads, (Copper?)
Location?
Dunno.
Sometimes under a piece of Mylar plastic, under the Wireless Module.
Sometimes under the Ram Memory module/s. ('Stick')
Sometimes on the bottom of the motherboard.
(THIS deters lazy thieves, lol!)
Best bet is to take it to an authorized Fujitsu representative, and your;
1) ID
2) Credit/Debit card
3) Proof of purchase
The rep will obtain a Master password. The rep KEEPS the master password.
The rep will then rest the password to one you want, or set it to NO password.
Use the software available on the internet?
Hmmm, let me see,....
Give my credit/debit card info, to an entity that is going to give a master password, to someone they DO NOT even know, and could have stolen the laptop.
Yep! That sounds like NOT!
Regards,
joecoolvette
May 11, 2012 | Computers & Internet
How do you reset cmos on fujitsu amilo pi 3540?
RTM - Read The Manual.
Get online and got to www.google.com In the google search box type: "Fujitsu Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals.
Sometimes you can take the laptop apart and remove the CMOS Battery.
It will be a silver battery about the size of a nickel on the motherboard. The most common size is CR2032. Also sometimes the battery will be in a vinyl covering and have a cable that attaches to a port on the motherboard. Which ever type you have you'll need to either remove the battery or unplug the cable and let the laptop sit for an hour or two. Then put it back, reassemble the laptop and reboot the laptop. With the CMOS battery out the computer will lose the date, time and password.
Bios clock has stopped on Fujitsu T4215 tablet pc. Have tried: 1) updating bios 2) re-installing cmos clock Clock starts again once in Windows (but from static date in bios) and can synchronize clock from...
I thik your CMOS clock (HH:MM:SS ) SS digit not moving forward. If it is then just unplug your CMOS Battery and 5 min later reassemble it ...your problem will be solved.if your BIOS whole setup reset including clock and SSS digit moving forward then replace your CMOS battery...if your not expert to open laptop then take a expart help to open it and run this procedure..
May 14, 2010 | Fujitsu LifeBook T4215 Tablet PC
CMOS settings on startup
If u mean by the internal battery ..the icon battery which placed on the mainboard .. so u just need to prss F2 to adjust the current date and time .. and to get stable Download the bios update from fujitsu.com .
good luck
Nov 10, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
When I turn my computer on, I get an istant error message: CMOS setttings error. Any idea what to do?
I THINK YOUR MOTHERBOARD BATTERY MAY BE DAMAGED OR DOWN. YOU HAVE TO REPALCE THE BATTERY AND TRY AGAIN TO START THE PC.
Oct 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Find the cmos battery in a Fujitsu Lifebook N3511
CMOS battery is located on the motherboard ...so you have to open the back cover of your laptop ...
May 07, 2009 | Fujitsu LIFEBOOK N3511 PC Notebook
Bypassing password
short out the jumper pins labeled CMOS
Jul 09, 2008 | Fujitsu Siemens Celsius R610 PC Desktop
Computers & Internet Logo
63 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
